Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Anybody mind sharing their car's setup? (camber/caster/toe)
  1. #11
    Join Date
    Sep 2006
    Location
    LI, NY
    Default
    What kind of tyres? This will matter most. Secondly, what kind of driving?
    Highly entertaining. For others.
    the "Snake Bit" 7 SV - zetec/sierra - yellow over green
  2. #12
    Join Date
    Mar 2014
    Default
    Quote Originally Posted by Boxologist View Post
    Nitto NT01s, 100 treadwear.
    Front 215/45-17
    Rear 255/40-17
    Spirited Sunday Canyon Carving, Autocross once a month, Track a couple times a year.
  3. #13
    Join Date
    Sep 2006
    Location
    LI, NY
    Default
    Look for 2.25 degrees camber up front. If you can adjust it somewhat quickly easily, maybe get it marked for 1.75 for road, 2.25 track, 2.75 or more for autoX. Shouldn't need more than 2.25 in the rear.
    5-6 degrees castor sounds fine. Minimal toe or what ever your preference is.
    I'd really look for more front tire if you can fit it on the autocross side.
  4. #14
    Join Date
    Nov 2006
    Location
    Texas
    Default
    I have run the NT01 before and I really liked it in the dry. In the wet can be a bit hairy hydroplane happens quickly. I think anything over -1.75 camber is going to have a detrimental effect. I'm sticking with the 1.25-1.5 range. As the front end is very adjustable the camber adjustment will effect other items like caster.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
