Results 1 to 5 of 5
Thread: Weber DCOE40 Italian linkage
  1. #1
    Join Date
    Apr 2013
    Location
    Denver Co.
    Default Weber DCOE40 Italian linkage
    I just replaced my departed 1700 Kent carb linkage that nobody could help me repair with a MANGOLETSI low profile single cable kit WEBL4241 from Burton Power in England. It cost $87 + shipping and is a very nice strong unit. It required rerouting the ignition wires and sawing out the bridge piece between cylinders 2 & 3 on the aluminum intake manifold that was easy and can be done in situ. It requires gas line rerouting but the only hard part there is finding the right parts at the right price (also from England). What a nice crisp throttle control and it misses the bonnet by a whopping 3.5 mm.
  2. #2
    Join Date
    Aug 2006
    Location
    Virginia, USA
    Default
    State side try http://www.rdent.com/ Look under Carburetor then Linkage. I've been using one of these on my Elan for years. Nicely built and they work well.
    Dean G.
  3. #3
    Join Date
    Feb 2020
    Default
    Quote Originally Posted by whotoo View Post
    Sorry to bump this old thread. Whotoo, could you post a couple pics of your carbs mounted to the manifold with the linkage installed? I’m curious about which pieces you used to connect the throttle shafts and how much you cut out of the manifold.
    I also have a 1700 Kent and I recently tried to install a similar linkage but ran into the same issue. My linkage appears to be a generic version of the Mangoletsi but virtually identical in function.
    Also upon looking up new intake manifolds from Burton I can see they are designed with that middle section missing between the carbs.
    Thank you!
  4. #4
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    According to whotoo's profile page, he last visited the forum in 2014, so I wouldn't count on a response. Hopefully someone else with experience in this area will chime in.
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  5. #5
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    E55, it might be worth looking at this thread on Elan.net that was started yesterday The person has the Mangoletsi on his Twin Cam and didn't want to remove material from the intake manifold, so came up with solution. Might work for you as well, or give you some inspiration for a different workaround.
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
Posting Permissions
  • You may not post replies
  • You may not edit your posts
