Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 45
Thread: Wanted 6" and 8" 13" Caterham wheel
  1. #31
    Join Date
    Sep 2005
    Location
    St. Louis, MO
    Default
    I'm not sure I'd put too much stock in the Caterham hp estimates. My Crossflow was originally the same spec as yours, and then was upgraded to the 150 hp spec by changing the cam to the Kent 244. I did a dyno day about 5 years ago, and I think I had 109 at the rear wheel.
    I missed both a BDA and a BDG that Craig Chima was selling, so opted to go ahead and "refresh" my Crossflow. Curtis Farley, who is a fairly well known Formula Ford engine builder, is doing the work.
    The only major component upgrades are forged pistons and SCCA SCAT crank. The crank should allow me to comfortably move my redline from 6500 to 7000. Already have double valve springs and roller rockers, but the valve springs are being replaced.
    Some head work had been done, but Curtis said it was like they got 75% done and then stopped, so he's "cleaning up" the head. Valves are slightly larger and, in Curtis' words "kinda slick" - although he didn't give me any details as to why.
    He thinks the compression ratio was below 9.5, but expects it to be slightly over 10 when he's done. No surprise here, but Curtis hasn't/won't make a prediction of hp. I'll be happy with a true 150 at the crank.
    175? From what I've read on Blatchat, it's possible. But I think it's also expensive. For starters, a steel crank - which runs around $2-2.5k (the SCAT crank is less than half that).
    Haven't given up on converting to a BDA at some point, but this will tide me over for a bit.
    Steve
  2. #32
    Join Date
    Dec 2012
    Location
    Gold Country Region, Northern California
    Default
    Thanks guys for putting my HP numbers in perspective. I was always referring to crank HP and now seem to remember the local market might have gotten close to 135hp with higher octane fuel and that the US cars were detuned to close to 125hp. Has anyone heard that tale?
    I am really happy with the HP I have now and whatever I do to increase it, even by 20 HP will make me even happier
    Thanks for all the advise, would love to hear what other owners have done to bump up engines from stock
  3. #33
    Join Date
    Oct 2006
    Location
    Cincinnati
    Default
    Ivey Engines in Portland, OR is an established, reputable X-flow rebuilder/upgrader.
    '09 Birkin S3, Duratec-sold
    '03 Caterham Zetec track car
  4. #34
    Join Date
    Dec 2012
    Location
    Default
    I know this is an old post, I was just revisiting it to see about tires for my 6" X 13" Panasport Comp wheels. Four plus years since the last comment. Does anyone have a suggestion for track day tires for this wheel set that will not be used on the road, I have a set of 6" x14" wheels for street use.
    Also, my race engine was completed a year ago, almost and it was more than satisfactory. Here are the specs from an engine dyno
    Caterham Race Engine 2016
    Block: Ford OHV 2265E Kent AX Block
    Bore: 84 mm Stroke: 77.62 mm
    Capacity: 1721 cc
    Compression
    Ratio: 11.5:1
    Maximum
    Power: 160 HP at 7,200 RPMs
    (At flywheel)
    Maximum
    Torque: 125 ft/lbs at 5,600 RPM’s
    Ignition Timing: 12 degrees B.T.D.C. at 1,200 RPMs
    OR 34 degrees B.T.D.C. at 4,000 RPM's
    Valve Clearance (Hot): .018” / .018” ( I / E )
    Valve Clearance (Cold): .018” / .020” ( I / E )
    Spark Plug Type: NGK BKR7E
    Spark Plug Gap: .030"
    Firing Order: 1-2-4-3
    Fuel: 110 Octane (Shell Purple)
    Oil Type/Viscosity: Redline 40 wt Racing (10W-40)
    Oil Filter: MOBIL 1 (Part No. M1-301)
    Cylinder
    Head: Gas Flowed with Enlarged Ports
    Valves: Ivey, Oversize (Intake: 41mm, Exhaust: 35mm)
    Valve
    Springs: Ferrea (S10115) Heavy Duty, Duplex with
    Burton Hardened Retainers
    Camshaft: Kent A6
    Rockers: Burton High Lift Roller Rockers (1.69-1)
    Pistons: CP Carillo Forged 84mm bore 11.5:1 CR
    Flywheel: Stock Lightened to 12lbs. and balanced
    Con Rods: Stock Ford lightened and
    Balanced 600 g (with bolt)
    ARP Bolts
    Crankshaft: SCAT SCCA Crankshaft
    Clutch: Helix Cover
    Helix 3 paddle clutch plate
    Throw Out bearing (Burton)
    Ignition: Distributor: Pertronix Flame Thrower
    Coil: Pertronix Flame Thrower II
    Valve Cover: Caterham Cast Alloy with
    1700 Supersprint Script
    Lubrication: Titan 5 port Dry Sump Pump
    Six Quart Alloy Oil Tank
    Alloy Dry Sump Pan
    Remote Oil Filter Housing
    MOBIL 1 Oil Filter
    Intake
    Manifold Caterham Cast Alloy
    Matched to head and carbs
    Carburation: Twin Weber 45mm DCOE
    Air Filters: Weber three screen filters
    Header: Caterham Competition 4-1
    Collector 2” Outlet
    Stainless Steel
    Muffler: Magnaflow
  5. #35
    Join Date
    Dec 2012
    Location
    Default
    To conclude this thread, I did find 4 Panasport Competition 6" x 13" wheels
  6. #36
    Join Date
    Apr 2015
    Location
    philadelphiaish
    Default
    Quote Originally Posted by O Racer View Post
    Interestingly I find myself in need of a set of 13" wheels. Where did you get your Panasports?
    '87 Caterham Cosworth BDR 1700 "HPC Spec"
  7. #37
    Join Date
    Dec 2012
    Location
    Default
    inchoate A friend with a Seven knew of 12 slightly used 6" X 13" Lightweight Panasports for sale. He also knew of another Seven owner, so we bought and shared them. When I tried to buy them new 4 years ago they were not aviailable. I believe the distributor in the US is in LA. Check the Panasport site
  8. #38
    Join Date
    Apr 2015
    Location
    philadelphiaish
    Default
    interesting. there's no desperate need as these would be track wheels. i'll keep my ear to the ground and something will come along.
  9. #39
    Join Date
    Dec 2013
    Location
    Owings Mills, MD
    Default
    Inchoate,
    I've got a set of 6" (maybe7"??) x 13" wheels. They've always been track wheels that I got when I bought my car. Have old rains on them now which are beat.
    Just sitting in my garage. If you're close to Philly, may work well as I'm outside of Baltimore and don't really want to ship. Give me your email and I can try to send you some pics if you're interested.
    Jim
  10. #40
    Join Date
    Jan 2018
    Location
    California
    Default
    To bump an old thread, because my question is in-line with some of the information in here already:
    I'm trying to decide on new tires for my Caterham (Zetec, 200hp?), which came with 13x6 front, 13x8 rear wheels, shod with Kumho V700 215/50-13 front and 235/45-13 rear.
    Now, whether or not that's too much tire for the car is not my question here... These tires are old and I'd like to replace them (I think they were the "as-new" tires on the car when the build was completed in 2002).
    Now, the way I see it I've got two easy options:
    1) Avon ZZR or ZZS in the Caterham OEM spec sizes of 185/55-13 and 215/55-13
    2) Toyo R888 or R888R in 185/60-13 and 205/60-13
    Now, the Toyos are cheaper and can be mail-ordered, and are apparently very good tires.
    While the Avons (ZZS, anyhow) are probably better in the wet (relevant, although I'll usually only be drive in good weather), and may come up to temperature faster (relevant, since I drive on the street). The car will be used primarily for street driving. Autocrossing or track in the future? It's possible, but it's not my primary concern.
    One more data point: It seems that the Avons will be about $864 for a set from a local distributor. The Toyos could be landed for about $557. That's a big difference, but since they'll probably be on my car for quite some time*, I'm interested to hear whether it would be worth it to spring for the Avons.
    I'd welcome anybody's opinions on these two tires, or maybe another option I've missed**. Thanks in advance!
    *although probably not as long as the Kumhos have been on it, prior to my ownership!
    **I used to run 15" wheels on my AE86, the selection is downright bountiful in comparison to 13"!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
