Page 16 of 18 FirstFirst ... 61415161718 LastLast
Results 151 to 160 of 173
Thread: MightyMike's Stalker V8
  1. #151
    Join Date
    Feb 2012
    Location
    Roswell GA
    Default
    If the headlights are rotated to have the flat sides facing each other, would that make enough clearance?
    Only for service, reposition before flight.
    Life happens while you're making other plans
    1995 Caterham Crossflow RHD
    2013 Mini (Her's)
  2. #152
    Join Date
    Nov 2010
    Location
    Gresham, Oregon
    Default
    maybe make a bracket to move the lights forward to the nose taper to allow for tilt. more welding practice. or like the Ultralite mount onto the bonnet.
    Mike
    2005 WCM Ultralite S2K
  3. #153
    Join Date
    Aug 2009
    Location
    Littleton, Colorado
    Default
    Quote Originally Posted by m wirth View Post
    I hadn't thought of trying that - excellent idea!
    - Brunton Storker, LS3, Chassis 159
    http://www471.pair.com/stalkerv/gall...2_itemId=20165
  4. #154
    Join Date
    Aug 2009
    Location
    Littleton, Colorado
    Default
    Quote Originally Posted by coffee break View Post
    Also a great idea - thank you! I was trying to put a square through a square hole.
  5. #155
    Join Date
    Oct 2006
    Location
    Carmel, IN
    Default
    Quote Originally Posted by MightyMike View Post
    Mike, I had the same problem because the lights scraped the hood when you opened and closed it. I learned to squeeze both sides while standing in front of the car to avoid hitting the lights while lifting and lowering in those crucial areas of contact. I also considered cutting the hood off behind the nose, but did not do it.
    Jack
    JBanker
    2003 Stalker V6 with Clamshells (new owner C. Banker now in Maine)
    2009 turbocharged Ecotec SuperStalker
    1999 Miata MX-5 Classic Red (sold)
    2009 Miata MX-5 Grand Touring Competition Yellow
    Indy Region SCCA
    CHILL (Club House Indianapolis Lotus Lovers)
    Indy Miata Club
    http://www471.pair.com/stalkerv/gall...?g2_itemId=807
    http://www471.pair.com/stalkerv/gall...2_itemId=17181
  6. #156
    Join Date
    Oct 2006
    Location
    Carmel, IN
    Default
    Mike, I know you have custom headlights. I have 5" diameter motorcycle lights on chassis 21 and we put the same lights on chassis 106. The lights are also mounted on 2" tall standoffs that are about 1" in diameter.
    Jack
    JBanker
    Indy Region SCCA
    Indy Miata Club
  7. #157
    Join Date
    Aug 2009
    Location
    Littleton, Colorado
    Default
    I am leaning strongly toward affixing a pair of headlight brackets to the nosecone/bonnet contraption. The brackets would be bonded to the undersides and come out and up into the same position as the existing mounts.
  8. #158
    Join Date
    Jul 2007
    Location
    Bakersfield, Ca
    Default
    The Ultralite has the headlight mounts attached to the frame right below the hoodline. They're not attached to the bonnet.
    Click image for larger version.
Name:	s2k front.jpg
    "HECK IS WHERE PEOPLE GO WHO DON'T BELIEVE IN GOSH"
    2008 Ultralite S2K
    2016 Mazda CX-5
    2008 Volvo C30
    2005 Mini Cooper
    1999 Miata
    1967 Chevy C10
  9. #159
    Join Date
    Nov 2010
    Location
    Gresham, Oregon
    Default
    But, some are.
Name:	july ridge 6.jpg
    Mike
  10. #160
    Join Date
    Aug 2009
    Location
    Littleton, Colorado
    Default
    Headlights are now mounted to the nosecone/bonnet contraption. I used a 1/8" steel backing plate behind the fiberglass. I plan to run the lamp wiring through the holes on the brackets, over to the front of the nose cone, and then down to the bottom of the radiator.
    I need to trim and sand the fiberglass before I send it off for paint. I'm really looking forward to getting Storker back on the road before the snow starts.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
