Page 35 of 35 FirstFirst ... 25333435
Results 341 to 345 of 345
Thread: Stalker #85 headed back to Arkansas
  1. #341
    Join Date
    Feb 2009
    Location
    NYC
    Default
    I think some father and son bonding is needed. I would buy him that cheap Stalker in Denver with the LS engine. Then you can play tag on track together. Bring him up to NJMP and you can show him what lines should not be used.
    Mike
    2018 Caterham 420R wit 2L Duratec 210hp at Donington UK
    1985 Holden Commodore Group A (restoration - engine rebuild)
    1982 Ferrari 400i (catching up on deferred maintenance)
    1992 Ford Escort RS Cosworth (fettling after long period of storage)
    1990 Range Rover 2 dr Classic
  2. #342
    Join Date
    Jan 2007
    Location
    Shawnee, Ks
    Default
    I have a better idea. Let him borrow your #85 car and have him bring it to the Gathering May 10-13 in North central Arkansas. Since you can't make it. We'll make sure he obeys all the posted speed limits. Trust me. Russ
  3. #343
    Join Date
    Jul 2009
    Location
    Arkansas and . . .
    Default
    Quote Originally Posted by locost7018 View Post
    Stalker V8, chassis #85
  4. #344
    Join Date
    Jul 2009
    Location
    Arkansas and . . .
    Default A Bit More Prep
    With the NJMP 4th of July event little more than a week away, I finally got around to corner weighting the car. While still considered a heavy weight by most 7-ish standards, the car (with full fuel, 9qts of oil, Accusump/oil cooler system, track tire/wheel package and wings...no driver) weighed in at 1674lbs. To put that in perspective, that’s 76lbs less than it weighed pre-accident. Weight shedding came about via a slightly different chassis design, a definitely different cage design, an even lighter-weight battery, a rethinking of how I fastened the car back together and what materials were used, and, a little weight reduction here and there via trimming of components and the use of various sizes of Milwaukee hole saws.
    As for me, I’m a s bit more robust than I was pre-accident. I fear the only thing that’s going to take weight off of the LR is a healthy dose of Jenny Craig.
  5. #345
    Join Date
    Sep 2006
    Location
    Southeastern Pa.
    Default
    Shane, you better reread the NJMP tech inspection guidelines, specifically section 7 L. " All Holes in the bodywork must be filled"
    hopefully you can remedy that issue in the next week. Tom
    2000 Caterham Superlight #123
    1.8L VHPD Rover K Series
    2009 Caterham SV
    2.3L Cosworth Duratec
Posting Permissions
  • You may not post replies
  • You may not edit your posts
