Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Ford Type 9 oil change?
  1. #11
    Join Date
    Feb 2012
    Location
    Roswell GA
    Default
    The oil in the gearbox shouldn't need changing in the same way as engine oil. It isn't dealing with combustion products like the oil in the engine. As long as the tranny isn't getting any crap coming in, it shouldn't need to be changed to remove the dirty fluid.
    Life happens while you're making other plans
    1995 Caterham Crossflow RHD
    1990 Miata
    2007 GMC Sierra WT
    2013 Mini (Her's)
    2014 Outback
    JOHN DEERE D130
  2. #12
    Join Date
    Dec 2014
    Location
    Los Angeles
    Default
    On the advice of another owner, I welded a threaded bung in the right front corner of the cover to facilitate future servicing of the gearbox. Once you have filled the gearbox, you can mark a dipstick for reference. The right front corner is a location where the dipstick will reach the bottom of the case without screwing anything up. I have suctioned out the gear lube in the past through this port.
    I eventually got got tired of the oily residue that accumulates on the top of the cover. The box is vented through a small hole in the cover that is baffled by an internal plate attached to the upper selector shaft pivot. I recently welded an AN-4 bung in this location (after drilling it to size). I attached a 12” SS hose using a 90 degree fitting and a straight fitting at the other end. To this I attached a cross drilled cap and secured it to the frame in front of the tunnel opening. Now everything stays clean and dry.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
