Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Zetec sound?
  1. #11
    Join Date
    Sep 2005
    Location
    St. Louis, MO
    Default
    FWIW, the Crossflow in my Mallock sounds quite different from the Crossflow in my Caterham.
    The Caterham is more mellow, and pitched lower. More Baritone. The Mallock is brighter, harsher, and higher pitched. Closer to a Tenor.
    I’ve always assumed that much of it is from the higher compression ratio in the Mallock (either 12.5 or 13 to 1- can’t remember off the top of my head) and the cam profile. It also has straight pipes, no muffler.
    Steve
  2. #12
    Join Date
    Apr 2018
    Location
    Ft Lauderdale
    Default
    OK may not be a Zetec but this has gotta be the best recording of a Caterham engine (I would like to know where his mike was)
    https://www.youtube.com/watch?v=3jGi...nel=HusaRacing
    Life Can Be Cruel
  3. #13
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Have an embed from me
    I think the mic will be in front of the exhaust, which is likely rear exit just based on me hearing it (lack of wind noise is the giveaway). The mic is unable to cope with the input - that may sound good to you but the sound is breaking up. That tells me it is relying on the action camera to power the mic - no separate power source. A good powered mic will improve the quality of sound from what you hear.
    Mike
    2021 Caterham CSR "CatKong"
    1972 Lamborghini Espada GT
Posting Permissions
  • You may not post replies
  • You may not edit your posts
