Results 1 to 7 of 7
Thread: Nose cone Dzus Removal- Wing Clearance
  1. #1
    Join Date
    Feb 2020
    Location
    Redondo Beach, CA
    Default Nose cone Dzus Removal- Wing Clearance
    How do you all open the Dzus fasteners on the sides of the car? Seems they are extremely close to the wings. I've been using a screwdriver on the inside of the engine bay, but it seems there must be a better way.
  2. #2
    Join Date
    May 2018
    Location
    Albany, NY
    Default
    Quarter coin works in a pinch. Otherwise a short flat head screwdriver.
    If you're really fancy you can by a Dzus tool, although not sure how it fits.
    Generally there is decently ample room to fit even relatively bigger screw drivers. Could be different on an SV
    2001 Caterham Superlight R
  3. #3
    Join Date
    Sep 2006
    Location
    Southeastern Pa.
    Default
    With clams it is too tight to use a screw driver. A dime or penny works well as does a Dzus tool. With cycles on an SV screwdriver works fine
    2000 Caterham Superlight #123
    1.8L VHPD Rover K Series
    2009 Caterham SV
    2.3L Cosworth Duratec
  4. #4
    Join Date
    May 2012
    Location
    Norwell MA
    Default
    I use a washer of the right radius to fit the groove.
  5. #5
    Join Date
    Jan 2018
    Location
    Northern Virginia
    Default
    You need one of these.
  6. #6
    Join Date
    Feb 2012
    Location
    Roswell GA
    Default
    I use a little ratchet made for hex bits.
    Life happens while you're making other plans
    1995 Caterham Crossflow RHD
    1990 Miata
    2007 GMC Sierra WT
    2013 Mini (Her's)
    2014 Outback
    JOHN DEERE D130
  7. #7
    Join Date
    Nov 2007
    Location
    Okaloosa County, FL
    Default
    [QUOTE=CarlB;117632]You need one of these.[END QUOTE]
    Back when the F-4 Phantom II and other aircraft had multiple panels held on with Dzus Fasteners, Airmen called this a "Snoopy Tool" and before our legendary "tool control" programs, every flightline mechanic carried one in his pocket. Later, the Composite Tool Kit (CTK) program eliminated tools in the pockets, etc.
    2007 Caterham 7 SV
Posting Permissions
  • You may not post replies
  • You may not edit your posts
