Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: New battery installation
  1. #11
    Join Date
    Feb 2012
    Location
    Roswell GA
    Default
    If you don't have an amp meter installed, you could temporarily install one to monitor operation.
    Life happens while you're making other plans
    1995 Caterham Crossflow RHD
    1990 Miata
    2007 GMC Sierra WT
    2013 Mini (Her's)
    2014 Outback
    JOHN DEERE D130
  2. #12
    Join Date
    Jan 2020
    Default
    By now you probably have this figured out, but another thought came to mind. The BMS might also protect against temperature and not just input voltage. As a test of this or over or under voltage conditions, you could reinstall your old battery (or any lead-acid battery) connected to the alternator alongside your new battery so the alternator has somewhere to dump the charge if it is the BMS. The answer may not be to replace your battery, but to install something to protect the alternator should the battery be disconnected while the engine is running (by the BMS).
    Greg
Posting Permissions
  • You may not post replies
  • You may not edit your posts
