Results 1 to 8 of 8
Thread: Rear Light Connector
  1. #1
    Join Date
    Apr 2018
    Location
    Ft Lauderdale
    Default Rear Light Connector
    I am replacing the rear lights and looking for this connector
    Any pointers as to what type or where to get a couple?
    Click image for larger version.
Name:	Rear Light Connector .jpg
Name:	Rear Light Connector 2.jpg
    Thanks Steve
    Life Can Be Cruel
  2. #2
    Join Date
    Apr 2012
    Default
    A few years ago I wanted to match up the factory headlight and running light/turn signal light connectors (that were similar in appearance the one in your photo). While I eventually did track down the company that produced them it ultimately ended up being easier to buy the needed bits from Caterham.
  3. #3
    Join Date
    Nov 2006
    Location
    Higganum, CT
    Default
    Steve,
    I just purchased some of those econoseal J series connectors from this place: https://www.corsa-technic.com/catego...ategory_id=109
    I ended up getting several 4-way connectors and some extra pins and seals just in case. The prices seemed decent and I had the parts in less than a week. Could have been 3-4 days but can't remember. I'd buy from them again. Hope this helps.
    Bruce
  4. #4
    Join Date
    Apr 2012
    Default
    Good source! Thanks for sharing that.
  5. #5
    Join Date
    Apr 2018
    Location
    Ft Lauderdale
    Default
    Thanks ended up swapping them out for weatherpacks it is what I used for most other connections I replaced
    Life Can Be Cruel
  6. #6
    Join Date
    Nov 2006
    Location
    Higganum, CT
    Default
    Quote Originally Posted by Nick O'Teen View Post
    You're welcome, glad to help.
    Bruce
  7. #7
    Join Date
    Nov 2006
    Location
    Higganum, CT
    Default
    Quote Originally Posted by Brightonuk View Post
    Weatherpacks are a lot easier to source, that's for sure.
    Bruce
  8. #8
    Join Date
    Apr 2018
    Location
    Ft Lauderdale
    Default
    Quote Originally Posted by 11Budlite View Post
    Steve,
    Man wish I had come across this site before.. I rewired the whole dash with weatherpacks due to my OCD every time I took the scuttle off and saw the spaghetti of jumbled wires.
    At the time I thought the Weaterpacks were kinda clunky and big (I wired each circuit to it's own plug), now looking at these I could of used there wire to board Series and made it much neater.
    So now the next project is to rewire the whole thing again using this option
    https://www.corsa-technic.com/item.php?item_id=622
    (That OCD is nagging at me again)
    Life Can Be Cruel
Posting Permissions
  • You may not post replies
  • You may not edit your posts
