Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Issues with forum display?
  1. #11
    Join Date
    Apr 2020
    Default
    My view looks like SanderGA's screenshot. Checked firefox; looks fine. So it's a chrome issue I guess. I will see if there's a fix. It used to work fine.
  2. #12
    Join Date
    Jul 2009
    Location
    Arkansas and . . .
    Default
    Quote Originally Posted by KnifeySpoony View Post
    Delete Chrome history, close your browser, reopen and try again.
    Stalker V8, chassis #85
  3. #13
    Join Date
    Jun 2020
    Default
    Quote Originally Posted by xcarguy View Post
    I did that and replaced the IMS bearing and it works fine now. Thanks.
  4. #14
    Join Date
    Sep 2006
    Location
    Southeastern Pa.
    Default
    Sander I think your issue is that you are getting inference from the 996 forum
    Mangia bene, Ridi spesso, Ama molto, Guidare veloce
    2000 Caterham Superlight #123
    1.8L VHPD Rover K Series
    2009 Caterham SV
    2.3L Cosworth Duratec
  5. #15
    Join Date
    Feb 2012
    Location
    Roswell GA
    Default
    I've been spending too much time on BaT, I keep looking for the "thumbs up" button.
    Life happens while you're making other plans
    1995 Caterham Crossflow RHD
    1990 Miata
    2007 GMC Sierra WT
    2013 Mini (Her's)
    2014 Outback
    JOHN DEERE D130
  6. #16
    Join Date
    Feb 2010
    Default
    I also had this issue with Chrome recently. It seems to perceive the site as "not secure" and block the formatting/layout. If you click on that text (on the left of the address bar) and go to Site settings: you can mess around with one of the settings and revert it back to normal. Sorry, I can't remember which one did it for me.
  7. #17
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    This issue cropped up this morning for me in Edge but not Chrome, so messed around a bit. Given it worked fine in Edge using In Private browsing, I cleared the cookies (unsuccessful) then cleared the cache which corrected the issue. Give that a try if it happens to you. In the meantime, I'll connect with Mazda. I suspect this could be related to a recent Chromium update and either incompatibility with our older version of vbulletin, or the fact we don't have an SSL certificate.
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  8. #18
    Join Date
    Apr 2020
    Default
    Quote Originally Posted by Ferrino View Post
    Ok this worked. Went to site settings and said to allow insecure content and things look normal again.
    Thanks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
