Results 1 to 5 of 5
Thread: Wanted: Black Box!
  1. #1
    Join Date
    Jul 2018
    Default Wanted: Black Box!
    I have a 2015 Caterham 7 280. The turn signals and hazzard lights stopped working a couple of months ago. My mechanic traced the problem down to a black plasticbox about the size of a cigarette pack, but Caterham parts says these are back ordered in a serious way. Does anyone have one they would be willing to sell? If so, for how mych?
  2. #2
    Join Date
    Oct 2006
    Location
    Cincinnati
    Default
    I suspect one of the U.S. Caterham vendors will have one, have you tried (Beachman Racing, Rocky Mountain Sportscar, Sevens and Elans).
    Kitcat:AKA, Sir Spinsalot
    '97 Caterham Super Sprint, 1700 Crossflow-sold
    '09 Birkin S3, Duratec-sold
    '03 Caterham Zetec track car
    '19 Honda Type R, sold
    '19 Miata Clubsport
  3. #3
    Join Date
    Sep 2006
    Location
    Southeastern Pa.
    Default
    Try flipping the Hazard Switch off and on several times. I seem to recall this being a common problem and the UK lotus 7 guys on blatchat found this to be a solution. Worked for me once when mine failed like yours. Good luck. Tom
    Mangia bene, Ridi spesso, Ama molto, Guidare veloce
    2000 Caterham Superlight #123
    1.8L VHPD Rover K Series
    2009 Caterham SV
    2.3L Cosworth Duratec
  4. #4
    Join Date
    Jan 2020
    Default
    Also check that all wires are plugged securely into the alternator! I had the same problem and a loose alternator wire was the issue!
    1987 Caterham 1700 Supersprint
    2002 Porsche Boxster
    2004 Porsche Boxster S
    1941 Dodge Luxury Liner
    2009 Mercedes CLK 350 Cabriolet
    2017 Chevrolet Volt
  5. #5
    Join Date
    Nov 2007
    Location
    Okaloosa County, FL
    Default
    AS mentioned before, this has been addressed on "BlatChat" in the past. I "fixed" mine by flipping the light switches and the turn signals along with the Hazard switch, back and forth many times. It is corrosion in one of the switches, and I NORMALLY don't use my lights or flashers very often. OF course, I use my turn signals often, and you must flip the switch ON and then flip it off, as it is not self-cancelling. It was NOT the turn signal switch, in my case.....
    2007 Caterham 7 SV
Posting Permissions
  • You may not post replies
  • You may not edit your posts
