Results 1 to 6 of 6
Thread: Low Duratec cam cover
  1. #1
    Join Date
    Nov 2013
    Default Low Duratec cam cover
    I'm putting a 2.5L in Birkin and the oil filter cap is just a little too tall. I thought about getting the Raceline cover, but it isn't designed for coil on plug ignition. Does anyone know if Raceline cover can be used with coil on plug, or another alternative?
  2. #2
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    How much room do you need to free up? Massive Performance makes a low profile filler cap that might be enough. There may be similar options available from others or you could have someone 3D print a cap that provides necessary clearance.
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  3. #3
    Join Date
    Feb 2009
    Location
    NYC
    Default
    I thought Tom C solved this problem? Cannot remember what he did though.
    Mike
  4. #4
    Join Date
    Dec 2014
    Location
    Los Angeles
    Default
    Try Tom Carlin. He had some made locally. I have one and it is well done. It solved the clearance issue I had with running a 2.3 in a 2 liter chassis. Well machined, o-ring included as well as the low profile filler cap. I think it was about $400.
  5. #5
    Join Date
    Nov 2013
    Default
    Thanks!
  6. #6
    Join Date
    Dec 2014
    Location
    Los Angeles
    Default
    This is a recent shot of mine. The nice thing is that you can powder coat it to look fulfill your wildest imagination!
    Sent from my iPad using Tapatalk
Posting Permissions
  • You may not post replies
  • You may not edit your posts
