Results 1 to 10 of 10
Thread: Wanted: 13" wheels
  1. #1
    Join Date
    Jun 2020
    Location
    Syracuse NY
    Default Wanted: 13" wheels
    Looking for (2) 6" x 13" & (2) 8" x 13 wheels for my 2005 Seven Zetec.
    Currently have 15" at all corners, but would like to try this setup ... as many of you have recommended.
    (Demon tweeks supposedly had them coming in from the supplier this week, but there are delays.... and this summer is going by fast).
    Other sources or ideas are welcome.
    Thanks,
    Hal
  2. #2
    Join Date
    Jun 2020
    Location
    Syracuse, NY
    Default
    Depending on the bolt pattern and back spacing you need, I have purchased steel wheels made by Aero Race Wheels and Marsh Racing Wheels. There are other makes available, e.g. Diamond Race Wheels. Some of them can be purchased directly, or from Summit or Jegs or some of the other suppliers. They work fine for track days and autocross, and are relatively inexpensive. Hope this helps.
    Leo
  3. #3
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    Have you checked with Beachman Racing or Rocky Mountain Caterham? They both have parts inventory and it's possible one/both of them have the 13" wheels in stock.
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  4. #4
    Join Date
    Jun 2020
    Location
    Syracuse NY
    Default
    Leo,
    Thanks for the input! I will check out those sources ASAP.
    Hal
  5. #5
    Join Date
    Jun 2020
    Location
    Syracuse NY
    Default
    John,
    I have not checked Rocky Mountain Caterham. I appreciate the input!
    Thanks,
    Hal
  6. #6
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Hi Hal,
    Depending on your hp level, a square set up (i.e. 6"x13 all round) is actually better if you have less than 180hp. The wider rears work better with higher hp as the engine can overpower the 6" wide rear set up.
    cheers
    mike
    Mike
  7. #7
    Join Date
    Oct 2006
    Location
    Cincinnati
    Default
    I make it a point never to disagree with Croc, esp on the issue of Caterhams and how to set them up. But really, about anything.
    But... my (maybe)150 hp Zetec SVT S3 Caterham has 6x13 in front and 7x15 in the rear for a non-square and staggered set up. It works great at the track(track only car), very neutral and balanced.
    Kitcat:AKA, Sir Spinsalot
    '97 Caterham Super Sprint, 1700 Crossflow-sold
    '09 Birkin S3, Duratec-sold
    '03 Caterham Zetec track car
    '19 Honda Type R, sold
    '19 Miata Clubsport
  8. #8
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Quote Originally Posted by Kitcat View Post
    oh but go on then....
    I am not saying it is a bad set up like you have it but I find a square set up in a lower hp car produces less understeer. I am thinking road more than track usage admittedly.
    Then again I do like throttle steering!
    Mike
  9. #9
    Join Date
    Jun 2020
    Location
    Syracuse NY
    Default
    Croc & Kitcat...... thanks for the input. I've been reading/following (don't worry ... not stalking) you guys for awhile (since I got my seven a year or two ago).
    I appreciate your guidance & comments!
    Hal
  10. #10
    Join Date
    Feb 2009
    Location
    NYC
    Default
    I am relaxed about you BeerCat - itís just Kitcatís stalking of me that freaks me out.
    Mike
Posting Permissions
  • You may not post replies
  • You may not edit your posts
