Results 1 to 2 of 2
Thread: Throttle Cable End Fitting or New Throttle Cable
  1. #1
    Join Date
    Mar 2015
    Location
    Massachusetts
    Default Throttle Cable End Fitting or New Throttle Cable
    Hi All, the barrel end of my throttle cable broke off while driving, does anyone know where I can find a new one? It was an 8 mm diameter barrel end. It's not clear if the actual cable broke or if the barrel end loosened and came off.
  2. #2
    Join Date
    Jun 2013
    Location
    N. California
    Default
    If the cable is 1/16" OD you can replace it with an appropriate bicycle cable. You can also solder on a new barrel end or purchase one that clamps on via a set screw. You may want to replace the cable, I had one die about 2 months ago and I now consider it a wear item. If you do use a clamp on barrel end be careful not to over stress the cable when you clamp it, it'll fail at the stress riser.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
