Results 1 to 6 of 6
Thread: Caterham CSR260 Fuel Pump
  1. #1
    Join Date
    Feb 2009
    Location
    NYC
    Default Caterham CSR260 Fuel Pump
    With Caterham no longer supplying the fuel pump as a part, this thread is a future memory aid to other CSR owners as they encounter this problem.
    According to both Cosworth and Minster, the CSR260 engine needs fuel pressure of 4.3 bar or 62 psi. Further, the pump needs to produce a fuel flow under load of 1.4 liters per minute.
    The original pump was used in the following vehicles:
    Rover 200 1.4i to 1.9i from 1995 to 1999
    Rover 400 1.4i to 1.6i from 1996 to 2000
    Rover 45 1.4i and 1.6i from 1996 to 2000
    And evil vehicles they were too.
    Mike
    1975 BMW CSL Group 4 (restoration finished - track set up time)
    1985 Holden Commodore SS Group A (suspension restoration)
    1985 Holden Commodore Group A (suspension set up)
    1982 Ferrari 400i (radiator replacement)
    1992 Ford Escort RS Cosworth WRC (dyno time)
  2. #2
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Photos of in tank pump
    Mike
  3. #3
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Close up of codes from tank top plate
    Mike
  4. #4
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Photo of pump mounted on top of tank
    Mike
  5. #5
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Matching up the part number WFX100631 produces the following part supplier
    https://rimmerbros.com/Item--i-WFX100631
    The fuel tank float is not correct for a Caterham fuel tank but the old one can be swapped over.
    A longer term solution is to open the white plastic housing and replace the internal pump itself should the housing become no longer available by way of this supplier.
    Mike
  6. #6
    Join Date
    Sep 2006
    Location
    Southeastern Pa.
    Default
    You forgot to mention you fixed your fuel gauge issue too with the swap.
    2000 Caterham Superlight #123
    1.8L VHPD Rover K Series
    2009 Caterham SV
    2.3L Cosworth Duratec
Posting Permissions
  • You may not post replies
  • You may not edit your posts
