Results 1 to 7 of 7
Thread: Harness for road and track
  1. #1
    Join Date
    Apr 2013
    Default Harness for road and track
    There's an existing thread on harnesses for track, but I'm starting this new thread relating a harnesses for road and track. It also seems that the FIA rules changed in recent years. I am having trouble finding any harness that works for me. My FIA 2019 belts are expired.
    Background:
    - Many (all?) tracks require 5 or 6 point belts in an open car like a Seven. 6 point are generally considered more comfortable, and safer I believe?
    - 2" shoulder belts are not supposed to be used without a HANS device.
    - Sevens use bolt-in harnesses.
    - As my seats are movable, I need adjustable lap belts. Pull-down adjusters fit in a Seven; I don't think there is room for pull-up adjusters.
    Given all of the above, I need belts that bolt in, are 6-point, have 3" shoulder belts, and have pull-down lap belt adjusters. As far as I can tell, this does not exist. It's as if I have to decide whether to drive my car on the street or on tracks - but can't do both. I'm very frustrated.
    Advice?
    1997 Caterham, BDA
    1991 Miata, supercharged
    2017 VW GTI
  2. #2
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Take one problem off the table. Don't use a HANS but look for something like the Simpson Hybrid which is intended to work somewhat more independently of the shoulder belts. The standard Caterham harness mounting points are too wide for a HANS anyway and need modification.
    https://www.simpsonraceproducts.com/...eck-restraints
    Mine has attachments to connect to the harness at the buckle. I went for this after my rather large scare 3 weeks back where I nearly rolled my seven and the lap belt attachments would hold you in better in the event of a roll over. After trialing last weekend, I felt much more tied in as I now have 10 points attaching me to to the car (6pt belts, 2 pt arm restrains, 2pt Simpson Hyrbid).
    You want a 6 point harness. It takes no great imagination to imagine what would happen to your babymakers in an accident when the 5th belt rams them lovingly through the roof of your mouth. My current Caterham 6 pointer (expiring 2021) has the design where they go through metal loops on the lap belt and then to the buckle. This puts the pressure on your inner thighs instead of potentially giving you a scrotal "degloving" (to use the medical terminology).
    I prefer the Caterham belts - they just fit. However, they are the old FIA designed (buckle on lap belt). The website does not show any harnesses in the new format right now. Maybe a phone call to Demon Tweeks in the UK to find out what others are using in FIA motorsport for Caterhams. We will not be the only ones with this issue and Demon Tweeks sell a lot of belts.
    I have seen Schroth also used in Caterhams - you need the openwheeler type with short lap and longer shoulder. I think they may be pull up.
    Mike
    1985 Holden Commodore Group A
    1982 Ferrari 400i
  3. #3
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    Shroth lap belts with the Flexi II option can be configured independently for either pull or pull down, and you can move the location of the adjuster to get it pretty close to the buckle. Comes in handy if you have something like Mog or Tillet seats.
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  4. #4
    Join Date
    Apr 2013
    Default
    Ok, after a bunch of phone calls, it looks like I've figured it out. I have ordered these Schroth FIA harnesses:
    https://www.schrothracing.com/item/p...tion-harnesses
    to be configured by them with bolt-on ends, pull-down lap belt configuration, and added sub belts, also with bolt-on ends. As a bonus the camlock lives on the lap belt, so I can use these as 4-point harnesses on the street, so I am getting everything I wanted. Many thanks to Zach at Schroth USA (800-884-2358) who helped me figure all of that out.
    Which I realize now is what JohnCh said above - thanks John. I understand it all now!
    1997 Caterham, BDA
    2017 VW GTI
  5. #5
    Join Date
    Apr 2013
    Default
    I have the Schroth Profi II set up. Do your sub belts attach at the rear bulkhead like they do on my SV? In my case I had to have HMS provide a custom length for the sub belts as the standard set up was too short. They were very accommodating but it was another $50 per belt to reweb with 6" more length.
    Jay
  6. #6
    Join Date
    Apr 2013
    Default
    No - sub belts attach along the sides.
    Quote Originally Posted by Black Hole View Post
    1997 Caterham, BDA
    2017 VW GTI
  7. #7
    Join Date
    Dec 2013
    Location
    Owings Mills, MD
    Default
    Check the size of the holes in the brackets from Schroth to make sure the bolts that hold your current harnesses will slide through. Otherwise you'll have to enlarge them.
    Jim
Posting Permissions
  • You may not post replies
  • You may not edit your posts
