Results 1 to 1 of 1
Thread: Sabre Seven - Car + Trailer + Spares - $14,900
  1. #1
    Join Date
    Jun 2020
    Location
    Syracuse, NY
    Default Sabre Seven - Car + Trailer + Spares - $14,900
    Sabre Seven (HS Engineering) Car + Trailer + Spares $14,900
    Mega professional updates. Was & can be street legal (needs emergency brake). $45,000 invested - my loss = your gain.
    Receipts available. $14,900 negotiable. PM me with questions.
    Car + chassis:
    1. HS Engineering Sabre 7 manufactured 1989 (featured in various kit car magazines)
    2. 91 wheel base
    3. California car with CARB sticker
    4. 1 square tubing frame
    5. Aluminum body + fiberglass clamshell front fenders + fiberglass rear fenders
    6. Aluminum cycle style front fenders fit 10 wide slicks
    7. Drivetrain and suspension Ford Pinto based with full custom racing upgrades
    8. Roll cage professionally built (bolt-in) SCCA road racing legal for next weight class
    9. Tops - #2 with doors
    10. Tonneau cover
    11. Gauges all new Auto-Meter (2019) except speedometer
    12. Switches & wiring new Painless Performance (2019)
    13. Windshield + #2 Brooklands style wind screens
    Drivetrain + related:
    1. Ford 2000cc 1972 professionally rebuilt with all performance parts
    2. Cylinder head professionally rebuilt October 2019
    3. Race type performance camshaft
    4. 10.5:1 compression ratio
    5. Dual Weber DCOE 40 carburetors
    6. Carter electric fuel pump new July 2019 + Holley fuel pressure regulator
    7. Custom ceramic coated headers + Magnaflow muffler
    8. 5.5 quart baffled custom oil pan
    9. Accusump oil accumulator 2 quart with electric on/off switch
    10. Oil cooler with integral fan (Derale)
    11. Custom radiator with switchable fans
    12. MSD 6AL ignition system adjustable rev limiter
    13. Distributor converted to Pertronix electronic
    14. Ford 4 speed close ratio transmission professionally freshened - rebuilt
    15. Clutch new - July 2019
    16. Currie Enterprises custom Ford 8.0 rear end (3.80 or 4.11 ratios) ok to 300+ HP
    17. Detroit Tru Trac posi differential
    18. Aftermarket rear axles big bearings
    19. Odyssey battery PC680
    20. Master shut-off switch
    21. Fuel cells - #2 @ 5 gallons each (Jaz aluminum - foam filled) + roll-over valve
    Brakes + Suspension:
    1. Wilwood Dynalite 4 piston calipers F/R
    2. Wilwood dual Master Cylinder
    3. Wilwood Proportioning valve
    4. Sierra Racing rotors (cross-drilled) + Carbotech pads
    5. Coilover suspension front (custom UB Machine) & rear custom 4 link
    6. Adjustable (single) shocks F/R Spax
    7. Corner weights adjusted professionally + alignment.
    8. Custom steering (MGB rack) - with quick release Mountney GT wheel
    Tires & Wheels:
    1. 5 - Carroll Shelby aluminum 14 x 6.5 street wheels & tires
    2. 4 Keizer lightweight 13 x10 aluminum wheels mounted with slicks
    3. 15 - steel 13 diameter race wheels (various widths) with slicks or treaded race tires
    Interior:
    1. Seats Kirkey aluminum high-back (driver) + Corbeau high-back (passenger)
    2. Harnesses 5 point driver (G-Force) & passenger (Impact Racing)
    3. Bulkhead with removable cover between passenger compartment and fuel cells
    Miscellaneous:
    1. Full lighting equipment and switches (headlights, parking, back-up, 4-way) + Horn
    Trailer:
    1. Eliminator by Unger & Wilhelm - custom dual axle 12 x 6 bed; 15 9 total length
    2. Trailer fits in standard garage garage kept at all times unless in use
    3. Tire rack holds 8 race tires/wheels + spare
    4. Front mounted spare tire for trailer
    5. Electric trailer brakes
    6. 14 trailer tires for lowered loading height
    7. Winch with remote control & custom mount
    Spares:
    1. 2 transmissions professionally rebuilt & not used (plus parts transmission)
    2. MSD 6AL factory rebuilt
    3. Muffler SuperTrapp
    4. Gas tank original custom 11 gallon
    5. Tire insulation blankets fit over slicks or race tires
    6. 4.11 rear end gear (almost new)
    7. Seats low back (need upholstering) include adjustable seat tracks
    8. Emergency brake handle and cable assembly
    9. Miscellaneous new gaskets, seals, bearings, thermostats, etc.
    10. Starter new (NAPA)
    Recent (2019) service:
    1. Cooling system flush and refill (October)
    2. Oil and filter change Brad Penn semi-synthetic 10W-30 (October)
    3. Brake fluid flush Castrol GT LMA (July)
    4. Differential fluid (July)
    5. Compete professional tune-up including carburetors (October)
    More pictures & video upon request.
Size:  49.4 KBName:  2.jpg
Size:  44.4 KBName:  10.jpg
Size:  20.8 KBName:  3.jpg
Size:  22.6 KBName:  12.jpg
Size:  24.4 KBName:  19.jpg
Size:  23.3 KBName:  38.jpg
Size:  23.0 KBName:  43.jpg
Size:  26.2 KBName:  25.jpg
Size:  23.3 KBName:  55.jpg
    Attached Images Attached Images
Posting Permissions
  • You may not post replies
  • You may not edit your posts
