Results 1 to 2 of 2
Thread: Sabre Seven - Car + Trailer + Spares - $13,900
  1. #1
    Join Date
    Jun 2020
    Location
    Syracuse, NY
    Default Sabre Seven - Car + Trailer + Spares - $13,900
    Sold today ! Thank you all for reading my adv't. I told the new buyers about this site, and how informative it is.
    Sabre Seven (HS Engineering) Car + Trailer + Spares $13,900
    Mega professional updates. Was & can be street legal (needs emergency brake). $45,000 invested - my loss = your gain.
    Receipts available. $13,900 – negotiable. PM me with questions.
    Car + chassis:
    1. HS Engineering Sabre 7 – manufactured 1989 (featured in various kit car magazines)
    2. 91” wheel base
    3. California car with CARB sticker
    4. 1 ¼” square tubing frame
    5. Aluminum body + fiberglass clamshell front fenders + fiberglass rear fenders
    6. Aluminum cycle style front fenders – fit 10” wide slicks
    7. Drivetrain and suspension – Ford Pinto based with full custom racing upgrades
    8. Roll cage – professionally built (bolt-in) – SCCA road racing legal for next weight class
    9. Tops - #2 with doors
    10. Tonneau cover
    11. Gauges – all new Auto-Meter (2019) except speedometer
    12. Switches & wiring – new Painless Performance (2019)
    13. Windshield + #2 Brooklands style wind screens
    Drivetrain + related:
    1. Ford 2000cc 1972 – professionally rebuilt with all performance parts
    2. Cylinder head professionally rebuilt – October 2019
    3. Race type performance camshaft
    4. 10.5:1 compression ratio
    5. Dual Weber DCOE 40 carburetors
    6. Carter electric fuel pump – new July 2019 + Holley fuel pressure regulator
    7. Custom ceramic coated headers + Magnaflow muffler
    8. 5.5 quart baffled custom oil pan
    9. Accusump oil accumulator – 2 quart with electric on/off switch
    10. Oil cooler with integral fan (Derale)
    11. Custom radiator with switchable fans
    12. MSD 6AL ignition system – adjustable rev limiter
    13. Distributor converted to Pertronix electronic
    14. Ford 4 speed close ratio transmission – professionally freshened - rebuilt
    15. Clutch – new - July 2019
    16. Currie Enterprises – custom Ford 8.0” rear end (3.80 or 4.11 ratios) – ok to 300+ HP
    17. Detroit Tru Trac posi differential
    18. Aftermarket rear axles – big bearings
    19. Odyssey battery – PC680
    20. Master shut-off switch
    21. Fuel cells - #2 @ 5 gallons each (Jaz – aluminum - foam filled) + roll-over valve
    Brakes + Suspension:
    1. Wilwood Dynalite – 4 piston calipers F/R
    2. Wilwood dual Master Cylinder
    3. Wilwood Proportioning valve
    4. Sierra Racing rotors (cross-drilled) + Carbotech pads
    5. Coilover suspension – front (custom UB Machine) & rear – custom 4 link
    6. Adjustable (single) shocks F/R – Spax
    7. Corner weights adjusted professionally + alignment.
    8. Custom steering (MGB rack) - with quick release Mountney GT wheel
    Tires & Wheels:
    1. 5 - Carroll Shelby aluminum 14 x 6.5 street wheels & tires
    2. 4 – Keizer lightweight 13 x10 aluminum wheels mounted with slicks
    3. 15 - steel 13” diameter race wheels (various widths) with slicks or treaded race tires
    Interior:
    1. Seats – Kirkey aluminum high-back (driver) + Corbeau high-back (passenger)
    2. Harnesses – 5 point – driver (G-Force) & passenger (Impact Racing)
    3. Bulkhead with removable cover between passenger compartment and fuel cells
    Miscellaneous:
    1. Full lighting equipment and switches (headlights, parking, back-up, 4-way) + Horn
    Trailer:
    1. Eliminator by Unger & Wilhelm - custom dual axle – 12’ x 6’ bed; 15’ 9” total length
    2. Trailer fits in standard garage – garage kept at all times unless in use
    3. Tire rack – holds 8 race tires/wheels + spare
    4. Front mounted spare tire for trailer
    5. Electric trailer brakes
    6. 14” trailer tires for lowered loading height
    7. Winch with remote control & custom mount
    Spares:
    1. 2 transmissions – professionally rebuilt & not used (plus parts transmission)
    2. MSD 6AL – factory rebuilt
    3. Muffler – SuperTrapp
    4. Gas tank – original custom – 11 gallon
    5. Tire insulation blankets – fit over slicks or race tires
    6. 4.11 rear end gear (almost new)
    7. Seats – low back (need upholstering) – include adjustable seat tracks
    8. Emergency brake handle and cable assembly
    9. Miscellaneous new gaskets, seals, bearings, thermostats, etc.
    10. Starter – new (NAPA)
    Recent (2019) service:
    1. Cooling system flush and refill (October)
    2. Oil and filter change – Brad Penn semi-synthetic 10W-30 (October)
    3. Brake fluid flush – Castrol GT LMA (July)
    4. Differential fluid (July)
    5. Compete professional tune-up – including carburetors (October)
    More pictures & video upon request.
Size:  49.4 KBName:  2.jpg
Size:  44.4 KBName:  10.jpg
Size:  20.8 KBName:  3.jpg
Size:  22.6 KBName:  12.jpg
Size:  24.4 KBName:  19.jpg
Size:  23.3 KBName:  38.jpg
Size:  23.0 KBName:  43.jpg
Size:  26.2 KBName:  25.jpg
Size:  23.3 KBName:  55.jpg
    Attached Images Attached Images
  2. #2
    Join Date
    Jun 2005
    Location
    North Potomac, MD
    Default
    Car is sold. Locking thread per user request.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
