Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: 310 Build Log - "I Don't Do This Because I'm Good At It. I Do It Because I Enjoy It."
  1. #11
    Join Date
    Oct 2019
    Location
    SE NC
    Default
    Quote Originally Posted by panamericano View Post
    "heater" ? My you Caterham lot are softies.
    what next, a fuel gauge?
    Henry
    1965 Seven S2
    1969 Elan S4
  2. #12
    Join Date
    Apr 2019
    Location
    Little Rock, Arkansas
    Default
    It took a little head scratching, but it finally occurred to me that, in order to get the "push-pull" of the heater cable to work properly, all I had to do was install the Heater Control Valve (HCV) upside down (and remember to reverse the hoses when I get to that part of the plumbing). I also have the ARB and the radiator installed).
Size:  38.1 KBName:  HCV Cable Layout.jpg
  3. #13
    Join Date
    Apr 2019
    Location
    Default
    The Engine is IN !
    I was little confused about a connector coming off the engine that didn't seem fit the connector it lined up with. Josh at Rocky Mountain Caterham figured it out for me. The receptor I had found was a "vestigial connection" left over from when they used K engines, so it can be taped off and ignored. The green connector coming off the engine goes to the MAP sensor, which Caterham had failed to attach to the chassis or include in the parts. It's on its way from Jolly Olde, so you can all look forward to questions about exactly how I attach that to the chassis and where the hose enters the intake manifold in a couple weeks.
  4. #14
    Join Date
    Feb 2009
    Location
    NYC
    Default
    The Sigma really does neatly package in a Caterham.
    I laughed at your heater deliberations - brings back memories of not being able to reinstall mine years ago. Gave up, was enjoying a beer when the lightbulb went off on how to install it.
    Mike
Posting Permissions
  • You may not post replies
  • You may not edit your posts
