Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Quaife Limited-slip Differential: how much noise is normal?
  1. #11
    Join Date
    Sep 2006
    Location
    Southeastern Pa.
    Default
    Vlad, you probably have a Sierra Diff with the ZF plate type LSD. Tom
    Mangia bene, Ridi spesso, Ama molto, Guidare veloce
    2000 Caterham Superlight #123
    1.8L VHPD Rover K Series
    2009 Caterham SV
    2.3L Cosworth Duratec
  2. #12
    Join Date
    May 2014
    Default
    Rocky Mountain Caterham was very helpful. Josh has a hearing impairment that makes e-mail a better option for him. They have a lot of diff parts in stock. I talked to Ross, Josh's father.
    There's also Burton Power in the UK.
    Amazingly, Burt, my diff guy, was able to order all that was needed from his usual supplier. He uses an old transmission casing for his mailbox!
  3. #13
    Join Date
    May 2014
    Default
    Burt was unable to get the right parts for the pinion gear in my diff. He had to send some stuff back to Burton in England. It's the Ford Sierra diff, built by Quaife. Burt had a very low opinion of the way it was set up.
    I might end up buying a new diff., having Burt take it apart to be sure it's properly assembled and then install in my car.
  4. #14
    Join Date
    Jun 2013
    Location
    N. California
    Default
    I'd be interested in his comments on the setup if he's willing to share 'em.
    Andy
  5. #15
    Join Date
    May 2014
    Default
    I don't think he had ever seen a 7" Ford diff. He did admire the car, even though he was about 200 lbs too heavy to get in it.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
