Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Quaife Limited-slip Differential: how much noise is normal?
  1. #1
    Join Date
    May 2014
    Default Quaife Limited-slip Differential: how much noise is normal?
    I've got a Quaife limited-slip diff on my '07 Caterham and worry about the amount of noise that's coming from it.
    Do any of you guys have that diff and could tell me what living with yours is like?
    JR
  2. #2
    Join Date
    Apr 2007
    Location
    Bozeman MT
    Default
    I have one installed in the Ford Sierra diff in my Westfield. I can hear it (not surprising given that it's 6" from my elbow) but it's nothing that really sticks out in my mind.
    What kind of noise does yours make and when does it do it?
    dave
  3. #3
    Join Date
    May 2014
    Default
    It whines under load at speed greater than about 30 mph.
    I have a video that has a good example of the sound.
  4. #4
    Join Date
    Aug 2006
    Location
    Houston, Tx
    Default
    They are noisy. You will get use to it.
  5. #5
    Join Date
    Apr 2012
    Default
    Quote Originally Posted by Road Ready View Post
    All the time or just while cornering?
  6. #6
    Join Date
    May 2014
    Default
    My car is in the shop of a guy who's supposed to be nth local diff genius.
    He may be asking me for the phone number of a parts source for pinion bearing and related parts.
    Nobody picked up at Rockey Mountain Caterham.
    Who next best?
    John
  7. #7
    Join Date
    Feb 2006
    Location
    Erie, CO
    Default
    I had one installed in my 2005 SV. It made a lot of noise on acceleration and deceleration. There also seemed to be too much back lash on the ring and pinion. Twice I had Nathan Down (formally of Caterham and Rocky Mountain Sports Cars) inspect and drive it and both times he said it was normal.
    I had the Quaife installed while I was building the car so I didn't have a chance to compare its noise level to the non LSD that came with the car.
    Skip
    Gone but not forgotten: 2004 Caterham SV: http://www.britishv8.org/Other/SkipCannon.htm
  8. #8
    Join Date
    Apr 2019
    Location
    So UT and Big Island
    Default
    John,
    In my experience, Josh responds faster to email than phone, try him at josh.robbins@rockymountaincaterham.com
    Jim
  9. #9
    Join Date
    Apr 2007
    Location
    Bozeman MT
    Default
    I'll echo Scannon's input....the Quaiffe makes it sound like there's too much backlash in the gearing. I had one in an Elise and it sounded the same way.
    dave
  10. #10
    Join Date
    May 2018
    Location
    Albany, NY
    Default
    I checked and it appears I have a ZF rear end. Whatever is is. I don't believe I have a Quaife.
    2001 Caterham Superlight R
Posting Permissions
  • You may not post replies
  • You may not edit your posts
