Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
Thread: 2005 Caterham SV for sale
  1. #21
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    To add to the above, the SVT has bigger valves and redesigned intake ports. I believe the short block adds forged pistons and oiling changes. Stock to stock, the SVT is a big upgrade over a regular Zetec.
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  2. #22
    Join Date
    Jun 2007
    Default
    SVT also has variable intake cam timing and a 2 stage intake manifold that shifts to shorter runners above 6,000RPM.
    2006 Caterham 7 SVT(sold)
  3. #23
    Join Date
    Oct 2006
    Location
    Cincinnati
    Default
    I have had 2 SVT engines in my current Cat. The first, well tuned one, made about 162 hp and 148 lbs torque, on a chassis dyno. The second, as of yet untuned one, made 148 hp and 136 torque, per my faltering memory.
    Basically, the SVT falls a bit more than half way between the stock Zetecs, which were lucky to get more than 124-135 hp on a chassis dyno, and the Duratec, which I had in my Birkin and which made around 169 hp and 155 lbs torque, on the same dyno, again per my faltering memory.
    Forum member, 1 TurboFocus, an expert on Zetecs, says, for all practical purposes, the SVT was a different engine than the stock Zetec. Anyhow, it is a nice, torquey, easy to drive engine that red lines around 7200. It weighs maybe 35 lbs more than the Duratec, in standard form and isn't as amenable to tuning as the Duratec. Because of its broad torque range, it matches well with the 5 sp transmission (no need to keep it on the boil).
    As a reference point, my '19 MX-5's (Miata) ultra-modern "Skyactive" Mazda 2.0 liter engine is rated at a bit more power than the SVT on paper but on the dyno the numbers are similar or less, than the the SVT. That's progress. Or maybe emissions and mpg issues???
    Kitcat:AKA, Sir Spinsalot
    '97 Caterham Super Sprint, 1700 Crossflow-sold
    '09 Birkin S3, Duratec-sold
    '03 Caterham Zetec track car
    '19 Honda Type R, sold
    '19 Miata Clubsport
  4. #24
    Join Date
    Aug 2006
    Location
    Houston, Tx
    Default
    I (we) currently have a Caterham Zetec (his), a Caterham SVT (her), and a Caterham R300 Durtec (ours). Each one is a fantastic driver with a different experience. I (we) have no favorite because they all put a smile on my (our) faces.
  5. #25
    Join Date
    Feb 2012
    Location
    Roswell GA
    Default
    pksurveyor, you give a whole new meaning to being "cat" people.
    Life happens while you're making other plans
    1995 Caterham Crossflow RHD
    1990 Miata
    2007 GMC Sierra WT
    2013 Mini (Her's)
    2014 Outback
    JOHN DEERE D130
  6. #26
    Join Date
    Aug 2006
    Location
    Houston, Tx
    Default
    His Zetec, Her SVT, Our Durtec.
Size:  42.7 KBName:  11-16-2008  41.jpg
  7. #27
    Join Date
    May 2007
    Location
    bethesda maryland
    Default
    sold?
  8. #28
    Join Date
    Aug 2012
    Location
    Memphis
    Default
    Yes. I've had a ton of interest, but car still available.
    PM, serious inquiries only, please.
    Sandfire
  9. #29
    Join Date
    Aug 2012
    Location
    Memphis
    Default
    Sold.
  10. #30
    Join Date
    Oct 2006
    Location
    Cincinnati
    Default
    Congratulations! Someone got a great car.
    '19 Miata Clubsport
Posting Permissions
  • You may not post replies
  • You may not edit your posts
