Results 1 to 6 of 6
Thread: Corner balancing scales
  1. #1
    Join Date
    Apr 2018
    Location
    Ft Lauderdale
    Default Corner balancing scales
    Around 200+ bucks at a alignment shop and a cheap set for less than $400
    https://autoplicity.com/11245808-lon...hoC2w8QAvD_BwE
    And as I will only need to use them once (if I can keep the weight off) I thought if a few guys want to split the cost and try this them selves I would buy a set and then pass it on to the next person.
    Life Can Be Cruel
  2. #2
    Join Date
    Jun 2013
    Location
    N. California
    Default
    Too bad you're in Florida, I picked up a set for the Shop last year...
    Try some of the local race shops. Anyone working with formula cars should have a set. You may be able to rent them for a few days.
    You may keep an eye out for a used set as some teams and individuals may have budget issues and be selling off surplus equipment.
    ps. The price you found is for ramps, not scales! Scales are a bit more $$
  3. #3
    Join Date
    Apr 2012
    Default
    Given that LOW price I just checked out that part number on line and it looks like it is not for a set of scales, but for a set of ramps used to roll a car up on to the scales.
    http://www.longacreracing.com/products.aspx?prodid=8008
  4. #4
    Join Date
    Apr 2018
    Location
    Ft Lauderdale
    Default
    Yep to good to be true I was looking at the photo but the description is for ramps
    Life Can Be Cruel
  5. #5
    Join Date
    Nov 2010
    Location
    New Jersey
    Default
    Many years ago I purchased four regular bathroom scales to corner weight a single seater. It actually worked well providing you carefully and gently placed the car and ‘calibrated’ each set by standing on them. I think the scales were about $20 each.
    1985 Caterham Super Seven
    1952 MG TD
    1991 Lotus Elan
    2017 MX5 RF
    2018 Audi A5 Sportback
    2014 BMW X1
  6. #6
    Join Date
    May 2010
    Location
    Laurel MD
    Default
    Not quite $20 each but close, I know people that are using these.
    https://www.amazon.com/Smart-Weigh-S...sparkle_asin_0
    Graham
Posting Permissions
  • You may not post replies
  • You may not edit your posts
