Results 1 to 4 of 4
Thread: Lotus/Caterham Exhausts
  1. #1
    Join Date
    Jul 2009
    Default Lotus/Caterham Exhausts
    I have a couple of different side exhausts from different race car projects that are now extra to my needs. Both would be ideal for Ford motor cars as they are 4 into 1 collectors with 1 5/8" tubes. Both are 38.5" long from tip-to-tip and the one has an extension with turn out that brings total length to just about 50". Both also have Supertrapp muffler systems on them and will include extra plates as needed for both. Both also have bungs welded in for Oxygen sensors. $50 each which is about 20% of the cost of the parts that were used to build them. Craig Chima, CC Motorsports, Akron, OH. (330) 807-0742 or chima97@aol.com
  2. #2
    Join Date
    Jul 2013
    Default
    Do you know how many db.s they knock the noise to?
  3. #3
    Join Date
    Jul 2009
    Default
    Kind of a subjective question as depends on where "sound" readings are taken, max rpm used at sound station, and amount of plates used but under 98 for sure even with sound meter on the "exhaust" side of the track at 8000+ rpm and likely far less than that under different circumstances.
  4. #4
    Join Date
    May 2020
    Default
    Are these still for sale.
    Thank You
Posting Permissions
  • You may not post replies
  • You may not edit your posts
