Results 1 to 8 of 8
Thread: Converting from traditional to cycle wings
  1. #1
    Join Date
    Jan 2020
    Default Converting from traditional to cycle wings
    I have a cycle wing kit from Caterham and just read the installation instructions. They refer to the "prescribed position of the mounting holes" in the wing, but there is no position marked on the wings. These are the wings for 13-14" wheels. If anyone here can let me know where the prescribed positions are I'll appreciate it.
    Thanks/Anker
    1987 Caterham 1700 Supersprint
    2002 Porsche Boxster
    2004 Porsche Boxster S
    1941 Dodge Luxury Liner
    2009 Mercedes CLK 350 Cabriolet
    2017 Chevrolet Volt
  2. #2
    Join Date
    Apr 2019
    Location
    Colorado Springs, CO
    Default
    Without knowing what you got in your conversion kit, I should probably withhold comment, but that has never stopped me before. It seems to me that the method the factory recommends for wing installation on new kits might work best here too...glue them on. Using Sikkaflex 721 place a bead along the top of the stay where it touches the fiberglass wing then use tape to the wheel to hold it firmly overnight until it sets. Then put a nice cove bead of the stuff on both sides of both stays. Job done. As for location, the front edge of the wing should be 80mm or 3 1/8 inches ahead of the top stay. This makes a clean and drilling free install that is really stout.
    Good luck with the new look!
  3. #3
    Join Date
    Feb 2009
    Location
    NYC
    Default
    My CSR wings are bonded on the same way I B Sevener describes.
    A variation on I B Sevener's very good suggestion above, that is common in the UK, is to use bigheads and bond the wing to it. Refer post 17 and 19 in the link below
    http://www.usa7s.net/vb/showthread.p...554#post113554
    I B Sevener is too modest but the reason bonding is a better idea than screwing wings on is that:
    - they are easy to cut off to remove or reposition if you goof up first time
    - no stress or fracture marks in the fiberglass wing around the bolt heads.
    Mike
    1985 Holden Commodore Group A
    1982 Ferrari 400i
  4. #4
    Join Date
    Jan 2020
    Default
    So I got the right front cycle wing installed. It looks great. It does, however touch the body side then the wheel is cranked way to the right. I tried the same on the left side and the mounting bracket does the same thing.
    Doesn't bother me, but I do wonder whether there is a stop that could be installed to prevent this from happening.
    2017 Chevrolet Volt
  5. #5
    Join Date
    Apr 2012
    Default
    Yep, Caterham can provide stops (aluminum bushings held in place by set screws) for use on the steering racks of cars with cycle fenders.
    You could also easily source an appropriately sized shaft collar such as one of these: https://www.grainger.com/category/po...ch-_-IDPPLACAT
  6. #6
    Join Date
    Oct 2006
    Location
    Cincinnati
    Default
    This helps explain why the turning radius of a cycle wing Cat is so much larger than one with clams.
    Kitcat:AKA, Sir Spinsalot
    '09 Birkin S3, Duratec-sold
    '03 Caterham Zetec track car
    '19 Honda Type R, sold
    '19 Miata Clubsport
  7. #7
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Quote Originally Posted by Kitcat View Post
    not if you just plant the right foot!
    Mike
    1982 Ferrari 400i
  8. #8
    Join Date
    Jan 2020
    Default
    Quote Originally Posted by Nick O'Teen View Post
    Thanks Nick,
    Simple. I didn't realize that it was that simple. Will take a look later today to see where they go and take measurements so I can order them.
    2017 Chevrolet Volt
Posting Permissions
  • You may not post replies
  • You may not edit your posts
