Results 1 to 5 of 5
Thread: Wanted - 3 rail "Bullet 2000E" shift lever assembly
  1. #1
    Join Date
    Jan 2018
    Default Wanted - 3 rail "Bullet 2000E" shift lever assembly
    Needs some help obtaining an old 3 rail "Bullet 2000E" shift lever assembly for a Mallock. Same as the original Elan trannys Actual lever shape not important. Any laying around out there? Thanks Chris D Name:  3 rail Ford Shifter.jpg
  2. #2
    Join Date
    Jun 2016
    Location
    Jacksonville, Fl
    Default
    Are you going to use this with the 3 bolt adapter at the end of the tailhousing (Integral Remote) or the 4 bolt adapter near the front of the tailhousing?
    My experience is that this one will only work with the 4 bolt adapter setup.
  3. #3
    Join Date
    Oct 2019
    Location
    SE NC
    Default
    Ray at rdent.com in the US and Steve at sjsportscars in the UK had them, at last check. Not cheap, though.
    Henry
    1965 Seven S2
    1969 Elan S4
  4. #4
    Join Date
    Aug 2009
    Location
    Escondido, CA
    Default
    Here's a long shot that might be worth a try. There's a gentleman near me that has a bunch of Cortina parts. He pretty much runs adverts continuously on the local craigslist:
    https://sandiego.craigslist.org/nsd/...097798961.html
    I've purchased a number of items from him over the years for my various Cortina, Lotus and Seven projects. The last item I bought from him was a transmission main case a while back.
    His name is Phil.
    Ron
    '14 Evora IPS
    '84 Turbo Esprit
    '77 S1 (deceased)
    '62 Lotus Seven S2 109E Cosworth
  5. #5
    Join Date
    Jan 2018
    Default Shifter
    Quote Originally Posted by Joe Petty View Post
    Correct. The 1/2 ball mounts directly to the top of the box cover with a round circular cone - not shown - but I need that too. The cone that supports the lever in place threads in the the ~ 4" x6" - 4 bolt, top cover.
    thnaks, Cd
Posting Permissions
  • You may not post replies
  • You may not edit your posts
