Results 1 to 10 of 10
Thread: Nothing is ever simple
  1. #1
    Join Date
    Sep 2006
    Location
    Southeastern Pa.
    Default Nothing is ever simple
    Well, last October i noticed a slight sound that went away when i lightly put my foot on the clutch. I assumed the throwout bearing as on its way out. I loaded up the car into the trailer and took it right to the shop. It sat there since then awaiting some attention. After several recent visits to kick a little ass, I went over yesterday and was pleased to see my car up in the air and sans engine and gearbox.
    I had left a box of parts to complete the job and thought it would be done this week. Then I saw this not so funny look on my mechanic's face. UH OH!!!
    it seems that the throwout bearing had seized and toasted not only the clutch, which I expected, but also affected the flywheel and input shaft seal on the gearbox.
    UH OH$$$$
    After a few calls and emails I finally heard back from SBD in the UK and Sadev in NC today and a new flywheel and ARP bolts are on there way. And I decided to send the gearbox down to Sadev in North Carolina for a refresh since it was already out.
    So i feel a little better today that i will get my car back on track in time for the start of the trackday season, albeit with a much lighter wallet.
    2000 Caterham Superlight #123
    1.8L VHPD Rover K Series
    2009 Caterham SV
    2.3L Cosworth Duratec
  2. #2
    Join Date
    Sep 2006
    Location
    Southeastern Pa.
    Default
    2009 Caterham SV
  3. #3
    Join Date
    Sep 2006
    Location
    Southeastern Pa.
    Default
    2009 Caterham SV
  4. #4
    Join Date
    Sep 2006
    Location
    Southeastern Pa.
    Default
    2009 Caterham SV
  5. #5
    Join Date
    Sep 2006
    Location
    Southeastern Pa.
    Default
    2009 Caterham SV
  6. #6
    Join Date
    Jul 2009
    Location
    Arkansas and . . .
    Default
    Tom, Iíd be more inclined to feel sorry for you IF you didnít have a backup Cat standing by.
    Stalker V8, chassis #85
  7. #7
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Okaaaaay.......can someone please explain to me how a throwout bearing can toast a flywheel and the gearbox input shaft seal? On a big hp V8 yes I get it but on a Caterham? Thats a new one for me.
    Mike
    1985 Holden Commodore Group A
    1982 Ferrari 400i
  8. #8
    Join Date
    Sep 2006
    Location
    Southeastern Pa.
    Default
    I asked the same thing Michael. Apparently it created a lot of heat.
    2009 Caterham SV
  9. #9
    Join Date
    Feb 2009
    Location
    NYC
    Default
    I'm hot too but I don't warp flywheels. Been known to destroy some seals in my time though...
    Is the flywheel alooooooooominum?
    Mike
    1982 Ferrari 400i
  10. #10
    Join Date
    Aug 2016
    Default
    Quote Originally Posted by Croc View Post
    It shouldn't.
    a Throw out bearing (TOB) doesn't make any physical contact with the clutch, or the flywheel, or the input shaft. There's usually a guide that the TOB slides on in the gearbox, but that guide isn't often attached to the input shaft.
    The TOB will only make contact with the fingers of the pressure plate. A frozen/seized TOB could ruin the fingers of the pressure plate, which in turn could break a clutch... but it's unlikely. The heat from the TOB would have to be intense to kill an input shaft seal, so much so that it would almost have to be user error (riding the clutch all the time).
    Flywheel won't be damaged by a TOB, unless improperly installed. A TOB shouldn't be anywhere near the flywheel.
    - 1300lbs, 170bhp. British.
    - 2350lbs, 610whp. British.
    - 2700lbs, 180bhp. German with a British accent.
    - 2700lbs, 200bhp. German.
    - 4700lbs, 577bhp. German.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
