Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: CR500 to ZZS
  1. #1
    Join Date
    Apr 2013
    Default CR500 to ZZS
    My CR500 tires are aged out and I need to replace them on my 7 SV. My car has 195/45-15 CR500 and the ZZS that has superseded them is available in a 195/50-15. My issue is clearance. I knew one of my cycle wings is very close to the tire (about 4mm) but when I was looking at the options to fix that I noticed my cycle wing stay is also very close to the tire. The wing I could shim but the stay is a trickier issue. Out of curiosity I looked at Caterham parts and note that they list certain stays as being for use with the ZZS/ZZR tires. So they must have made a slight change to account for the wheel diameter change (from 21.69 to 23.08 per Avon website). Has anyone made the switch between the tires and did you have clearance issues?
    I did a feeble attempt to flex the stay with the cycle wing still on to see if it would bend but it seemed fairly stiff. If that does not work I would likely heat it and try to bend it and I could buy new stays if i bugger them up as they are not too expensive.
Size:  79.3 KB Name:  20_02_02_jPhone_186.jpg
Size:  57.9 KB Name:  20_02_02_jPhone_188.jpg
    Jay
  2. #2
    Join Date
    May 2018
    Location
    Albany, NY
    Default
    The wingstays and fenders "float" with the tire.
    As long as there is any clearance at all, it shouldn't be an issue. Like motorcycle front and rear fenders which float with the suspension.
    I switched from Avon and while I'm not happy with the sizes they worked for now
    Sent from my Pixel 3a XL using Tapatalk
    2001 Caterham Superlight R
  3. #3
    Join Date
    Feb 2009
    Location
    NYC
    Default
    I use Avon ZZS on my silver CSR in 15 inch wheel size and they originally were on CR500. Just bolted on with no clearance issues. Not much help as it is a CSR not a SV. I also have the ZZS on 13 inch wheels on my 420R but as that was from the beginning I suspect it had the special stays you refer to from original build.
    Mike
    1985 Holden Commodore Group A
    1982 Ferrari 400i
  4. #4
    Join Date
    Apr 2013
    Default
    Quote Originally Posted by Vovchandr View Post
    Thank, I know they move with the tire and that is why the clearance with the CR500 is tight but not an issue. The wild card is when I go to the larger tire I may run out of clearance
    Jay
  5. #5
    Join Date
    Apr 2013
    Default
    Quote Originally Posted by Croc View Post
    Hopefully I will have the same experience. I will likely order them in the next week or two from Roger Krause. I will get them to fit somehow, just a matter of bolt on or have to make some modifications.
    Jay
  6. #6
    Join Date
    Feb 2009
    Location
    NYC
    Default
    And for the best bit of news, I think they are better than the CR500 being replaced
    Mike
    1982 Ferrari 400i
  7. #7
    Join Date
    Oct 2006
    Location
    Cincinnati
    Default
    The other wild card, I have discovered, is that with very minimal tire/fender clearance, wind pressure at high speeds will shove the fender onto the tire and cause significant rubbing. My efforts at bending the stays were minimally successful. I had more luck with imaginative shimming (as long as aesthetics aren't a concern, and on my Cat, they are not). Even then, I have trouble fitting a 13x185/60 on the front.
    Kitcat:AKA, Sir Spinsalot
    '09 Birkin S3, Duratec-sold
    '03 Caterham Zetec track car
    '19 Honda Civic, Type-R
  8. #8
    Join Date
    May 2018
    Location
    Albany, NY
    Default
    My new tires are 185/60r13 that are picturer above with the tight fit.
    The previous original R500 had a much more tollerant fit. Don't remember their size. But ill trying to order the same matching set as original again.
    Rears are a bigger problem. 245s are being very hard to find for the rear. And the current side wall at 45 makes them look very small in the arches and definitely much small than the 60 front.
  9. #9
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    I thought the CSR used 245 rears, but the S3/SV used 215? Does that significant difference in front & rear width result in a lot of understeer?
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  10. #10
    Join Date
    Jul 2013
    Default
    You might also think about trimming off some of the excess bolt length. I did so, not for the tires, but for using tire bonnets (straps) which caught on the bolts, between the tire and fender.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
