Page 14 of 15 FirstFirst ... 412131415 LastLast
Results 131 to 140 of 148
Thread: New Build
  1. #131
    Join Date
    Jan 2020
    Default
    Next step is to attach the shocks, but you can't access the holes to mount the roll bar through the chassis from beneath with the shocks installed.
    Oh those tricky Brits...
    Thankfully I noticed otherwise it would be annoying to learn I needed to dismantle the rear suspension later in the build.
    So here it is with the roll bar installed:
    Greg
  2. #132
    Join Date
    May 2018
    Location
    Albany, NY
    Default
    That honeycomb was a royal pita to move in and out with everything in.
    With that said, question. What is the material that you used between the tank and the frame. Soft double sided 3M molding type material?
    Mine disintegrated while I was troubleshooting a gas leak and was looking to replace it. Wasn't sure what it was. With you experience can I lift the tank from below and slide new material under or is this a bigger tank out job?
    2001 Caterham Superlight R
  3. #133
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    I'm surprised Caterham doesn't supply the boot floor in two pieces so it can be easily removed from above for maintenance access. I did my floor that way when building the larger custom boot box, and it has come in handy on a few occasions.
    Glad you figured out the assembly order of the roll bar and suspension before it was too late.
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  4. #134
    Join Date
    Jul 2013
    Default
    The original owner of my Birkin cut the fiberglass bottom out of the boot, leaving about an inch of floor around the perimeter. That holds the thick aluminum that is the new floor. It lifts out easily with a paint can opener, giving good access to everything below.
  5. #135
    Join Date
    Nov 2006
    Location
    Higganum, CT
    Default
    Quote Originally Posted by JohnCh View Post
    John - The Caterham floor is in two sections. There's the honeycomb section in the rear and a smaller plywood section in front with I believe an aluminum channel in between. The honeycomb is still a little difficult to remove without damaging the paint/powder coat on the chassis.
    Bruce
  6. #136
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    Thanks. I took the comment that the honeycomb has to be fitted prior to the fuel tank to mean that dropping in from above is difficult due to space constraints.
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  7. #137
    Join Date
    Jan 2020
    Default
    Quote Originally Posted by Vovchandr View Post
    Screwed down, no adhesive. I could not figure out a way to get the honeycomb out from the top, so am assuming it was installed from below first and then the tank.
    Greg
  8. #138
    Join Date
    Jan 2020
    Default
    Quote Originally Posted by 11Budlite View Post
    I tried every angle I could think of and every time it wedged against the painted skin that wraps around the frame along the opening of the boot. Maybe desperation would have given me inspiration, but all I needed was enough room to work with the dremel so I didn't push my luck.
    Greg
  9. #139
    Join Date
    Jan 2020
    Default
    Today was rear suspension day. No drama, but if there was a video of me with that A frame and you sped it up just a little I think it would pass as an episode of Benny Hill. I'd shim with washers to get the axle centered, measure, nod in satisfaction, torque, measure, mumble to myself, disassemble and repeat. Ironically, when all was said and done I wound up with an equal number of washers on both sides.
    Greg
  10. #140
    Join Date
    Jan 2018
    Location
    Wellsboro, PA
    Default
    Hi Greg, nice progress, I see you put in the A Frame. I hope you didn't make the same mistake I did and put it in upside down. LOL. I only noticed the difference in the guide after I put it in. Oh well, it wasn't the only time I had to pull something off and put it on again.
    Keep up the good work!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
