Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 72
Thread: New Build
  1. #31
    Join Date
    Sep 2006
    Location
    Southeastern Pa.
    Default
    Quote Originally Posted by Croc View Post
    I do like the box labelled "Shortages"!
    Yeah, when I assembled my Yellow car, I got bags labelled "front suspension" "Rear suspension" "Miscellaneous"
    And of course I found Front suspension bolts in the rear and miscellaneous bags. My wife was more concerned that after I completed the assembly, that I had A LOT of extra bolts, washers and nuts left over.
    It's held together pretty much for coming up on 20 years now, so I guess it's ok.
    Good luck with the build, you may have to grind the chamfer off of a cheap socket to tighten up the half head bolts for the underside of the roll bar if they still use that half depth bolt head. No biggie, but read the manual to check.
    Tom
    2000 Caterham Superlight #123
    1.8L VHPD Rover K Series
    2009 Caterham SV
    2.3L Cosworth Duratec
  2. #32
    Join Date
    Jan 2020
    Default
    Awesome kit you have right there! Can't wait to see the full build!
    Jason
  3. #33
    Join Date
    Nov 2006
    Location
    Higganum, CT
    Default
    Congrats on starting your build. Looks like a nice spec! I just recently sold my 64 MGB and a lawn tractor so have a little more room in my garage. Hope to be starting my 310S build pretty soon!
    Bruce
  4. #34
    Join Date
    Jan 2018
    Location
    Wellsboro, PA
    Default
    LOL when I unpacked mine it was short one headlight! It wasn't in the "shortages" box....
  5. #35
    Join Date
    Oct 2006
    Location
    Cincinnati
    Default
    Less wind resistance = higher top speed.
    Kitcat:AKA, Sir Spinsalot
    '09 Birkin S3, Duratec-sold
    '03 Caterham Zetec track car
    '19 Honda Civic, Type-R
  6. #36
    Join Date
    Jan 2018
    Location
    Wellsboro, PA
    Default
    The factory called it the Cyclops package when i wrote to them...LOL they sent me one in a couple days, all was good.
  7. #37
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Quote Originally Posted by Lucky-7 View Post
    The factory does have a keen sense of humor!
    Mike
    1985 Holden Commodore Group A
    1982 Ferrari 400i
  8. #38
    Join Date
    Feb 2010
    Default
    Yes - the famous "shortages" box. In some cases, it's more than one. If you can't find it in the appropriate box - immediately go to the shortages box(es). Generally, these are items that were OOS during the first pick for the kit.
    Also - for US-spec cars, ignore all references to "IVA" in the assembly guide - you won't have the parts anyway.
    Cheers,
    -Bruce
    Beachman Racing
    Authorized Caterham Cars dealer
  9. #39
    Join Date
    Jan 2020
    Default
    Inventory is done! Truth be told I haven't inventoried the contents of the various fastener packs and polythene bags. I'm not even sure if I have the correct fastener packs but the big bits are accounted for. So far all I've found missing is:
    1. One of the two door mirror plates,
    2. The green nyloc driveshaft nut, and
    3. Both front Watts link radius arms.
    A sampling of pictures follow...
    Click image for larger version.
ID:	16522 Click image for larger version.
ID:	16525 Click image for larger version.
ID:	16526 Click image for larger version.
ID:	16527 Click image for larger version.
ID:	16529 Click image for larger version.
ID:	16530 Click image for larger version.
ID:	16531 Click image for larger version.
ID:	16532 Click image for larger version.
ID:	16534 Click image for larger version.
ID:	16535 Click image for larger version.
ID:	16536 Click image for larger version.
ID:	16537 Click image for larger version.
ID:	16539 Click image for larger version.
ID:	16540 Click image for larger version.
    Hose or conduit, what is this mystery tube?
    And is this the right number of coolant hoses?
    Greg
  10. #40
    Join Date
    Jan 2018
    Location
    Birmingham, Alabama
    Default
    The mystery tube is one of the 2 radiator hoses, it runs from the rear of the engine to the radiator. I seem to remember the manual says install it before putting the engine in, but just put it in after. The 3 other hoses are also coolant but they will be chopped up. There should also be a 5/16" hose for coolant which connects to the water expansion bottle - I didn't get this hose either, but it's cheap and readily available so I ended up buying locally just to keep the project moving.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
