Results 1 to 4 of 4
Thread: Haltech Platinum Sport 1000 ECU with ignitors
  1. #1
    Join Date
    Nov 2013
    Default Haltech Platinum Sport 1000 ECU with ignitors
    I was using this Haltech Platinum Sport 1000 on my old Duratec 2.0 and upgraded to a new ECU with integrated ignitors. It also has an aluminum mount that is perfect under your dash shroud. These are about $1400 new + whatever the ignitors cost. I'll sell for $600. More info here.
Size:  44.4 KBName:  Haltech Ignitors Med.jpg
Size:  41.6 KBName:  Haltech Wide Med.jpg
  2. #2
    Join Date
    Jul 2020
    Location
    Austin,Tx
    Default
    Did this sell? I was considering using a Haltech. I’m interested
  3. #3
    Join Date
    Feb 2009
    Location
    The Frozen Northeast
    Default
    Out of curiosity- where were these mounted on your car?
    Ecu under scuttle on passenger side? Ignition module to water outlet connector?
  4. #4
    Join Date
    Nov 2013
    Default
    Yes, it has sold. Was mounted under the cowl on the passenger side. Ignition module on the water outlet. That is whet my ECU is as well.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
