Results 1 to 6 of 6
Thread: What calipers/rotors are on my Birkin
  1. #1
    Join Date
    Nov 2019
    Location
    Hudson valley, ny
    Default What calipers/rotors are on my Birkin
    Familiarizing myself with my new to me Zetec Birkin S3. It doesn't have wilwoods or anything fancy like that, car was built in 03 or so. Vented front, solid rear disc. Live axle rear. What was the common caliper and rotor used on here?
    Birkin S3, Dunnell Zetec Powered
    Toyota Celica GT-S, Toyota MR2 Turbo GT-S, Lotus Elise (RIP)
    Yamaha Bolt C-Spec, KTM 625 SMC, Yamaha TW200 scrambler, Yamaha SR250 tracker, Honda CB360 bobber
  2. #2
    Join Date
    Jul 2009
    Location
    Arkansas and . . .
    Default
    Photos, preferably with wheels off.
    Stalker V8, chassis #85
  3. #3
    Join Date
    Dec 2008
    Location
    Port Angeles, WA
    Default
    I don't have my notes handy, but from memory, they're from a '89-ish VW.
    Randall
  4. #4
    Join Date
    Dec 2014
    Location
    Los Angeles
    Default
    I understand that they are from ROW late 80s GTI/Jetta. Check with tbox56.
  5. #5
    Join Date
    Nov 2006
    Location
    Higganum, CT
    Default
    I don't have my notes handy but agree with the others. VW in the front with specially machined rotors, and I believe Honda (Civic/Accord?) in the rear. I'll see if I can find more info tonight.
    Some more info here: http://www.usa7s.net/vb/showthread.p...=birkin+brakes
    Bruce
  6. #6
    Join Date
    Dec 2014
    Location
    Los Angeles
    Default
    I know that on my 2015 Birkin XS, the solid rear rotor is from a ‘98 ROW GTI but it has been milled down on the inner side to. 10.5mm, approximately the minimum rotor thickness stamped on the outer edge. Weird but it allows the VW rotor to work with the proprietaryBirkin hub assembly. Wilwoods on the front.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
