Page 12 of 14 FirstFirst ... 21011121314 LastLast
Results 111 to 120 of 132
Thread: 2.0L Duratec Rebuild
  1. #111
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    It looks like the torque wrench is delayed. It left Fresno, CA on Monday and was supposed to arrive here today. Checking tracking, it was in Sacramento on Tuesday (good), hung around Sacramento until yesterday (less good), arrived in Troutdale, OR today at lunchtime (good-ish) and is now in transit to Westminster, CO (what???) I'm not great with geography, but even I know that's not on the way to Seattle. Tracking now says it will arrive tomorrow, but the CO mention doesn't inspire confidence. Time for a Martini.
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  2. #112
    Join Date
    Jul 2013
    Default
    Fear not! After it gets to Chicago, it MAY turn back west. Unless it goes to Atlanta.
  3. #113
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    FedEx has updated the tracking. It still shows it arrived in Troutdale yesterday around noon, and was in transit to Westminster shortly after, but they have now added that it left Troutdale last night (timestamped more than 8 hours after the In transit to Westminster timestamp) and arrived at my local hub early this morning. If that's true, I should have the head torqued this afternoon.
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  4. #114
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    Head is torqued, cams are installed, and the chain drive assembly with new mechanical chain tensioner is in place. The factory Duratec uses a hydraulic tensioner, which works fine, but can have issues in high rpm engines that result in over tensioning or broken teeth on the plastic ratcheting mechanism. The fix is a simple modification that replaces the plastic ratchet with a threaded metal stop.
    I ran into a slight issue when attempting to time the cams. Kent uses their own adjustable cam gears that aren't interchangeable with the factory set. For some reason the tolerances between my old gears and new DTEC20 cams are much tighter than with the old DTEC10 cams. They're more of a press fit than a slip fit which means they aren't really adjustable, but I tried anyway until running out of both patience and time. I'll remove the timing chain and cam gears tomorrow, take some measurements, and figure out if lightly sanding the coating might free up enough room. If not, I'll call Kent on Monday.
    Name:  timing wheel.jpg
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  5. #115
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    I removed the timing chain and exhaust side gear from the engine, and put the gear on a DTEC10 cam to make sure my memory of fit was correct. Surprisingly it was. Although tight, the gear was easy to rotate on the cam end by hand. In contrast, the gears are a tight enough fit on the new DTEC20 cams that a gear puller is required to remove them. The calipers showed the problem. The nose of the cam end that forms the stop for the bolt and sticks through the face of the gear (see left side of photo) is .006" wider than the nose on the old cams. Just enough to cause a problem. I think I'll hold off any attempts to enlarge the hole in each gear until I can speak with Kent Cams tomorrow.
    Name:  cam end sm.jpg
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  6. #116
    Join Date
    Jul 2009
    Location
    Arkansas and . . .
    Thumbs up
    John, for the next guy that walks this path...the manual is this thread. Been interesting following.
    Stalker V8, chassis #85
  7. #117
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    Thanks Shane. I must admit I never intended for the thread to become this interesting, or to last this long.
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  8. #118
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    After unsuccessfully trying to reach Kent's technical department for the past hour (I'm sorry, no one is currently available to take your call), I had an epiphany and did a search. Yep, today is also a holiday in the UK. Do we have a Bollocks emoticon?
    Edited to add the new Bollocks emoticonName:  bollocks2.jpg
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  9. #119
    Join Date
    Jul 2009
    Location
    Arkansas and . . .
    Default
    Quote Originally Posted by JohnCh View Post
    Will this work.......
  10. #120
    Join Date
    Feb 2012
    Location
    Roswell GA
    Default
    Is that a "Big Hairy ???"
    Life happens while you're making other plans
    1995 Caterham Crossflow RHD
    1990 Miata
    2007 GMC Sierra WT
    2013 Mini (Her's)
    2014 Outback
    JOHN DEERE D130
Posting Permissions
  • You may not post replies
  • You may not edit your posts
