Page 1 of 21 12311 ... LastLast
Results 1 to 10 of 209
Thread: 2.0L Duratec Rebuild
  1. #1
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default 2.0L Duratec Rebuild
    I'm very late starting a thread on my engine rebuild, so I'll begin with posts over the next couple of days to catch up everyone on the status. For background the oil pressure relief valve appears to have failed, taking with it the mechanical oil pressure gauge. The simple solution was to replace the gauge and the oil pump and quickly get back to the end of blatting season, but sadly I don't do simple. Instead, I've opted to do things the slow, pricey, hard way with a full rebuild and performance upgrade. My garage is now in chaos.
    The first 8,500 miles of my 2.0L Duratec's life were covered with stock internals, while the last 24,000 were with Kent DTEC10 cams, stiffer valve springs, some head work, and ARP Rod bolts. For the latest iteration, cams are changing to DTEC20s, pistons to Omega (11.7:1 vs. stock Mondeo 10.8:1), rods to forged items from K1, crank will be keyed and the bottom end fully balanced. The goal is 225-230hp, with limited torque loss from 2000-3000 rpm, similar torque from 3000-5000rpm, then a noticeable jump from there to 8000rpm with the ability to rev higher if needed.
    Cam selection was a struggle. After much internal deliberation, protracted mulling over specs, and multiple conversations with people of various expertise, I decided that for my specific goals, DTEC20s were the right choice. Interestingly, feedback from everyone but Kent was consistent: if you are going through the effort of changing pistons so you can add more lift than DTEC10, you should step up to cams that can support 250+ hp. Although Kent makes cams in that category (the DTEC35 are essentially the R500 cams and they have even more aggressive grinds available) they alone told me I wouldnít be happy with the bottom end of anything with that much overlap. Also, and this is something that particularly resonated with me, the gap between the DTEC20 and DTEC 10 is much larger than the gap from stock Mondeos to DTEC10. Since I previously make that switch and was pleased with the performance increase, it seemed to me that the jump to DTEC20 would suffice.
    The chart shows how the various cams under consideration compare and includes the stock Mondeo cams and DTEC10s for baselines.
    Name:  cam table.jpg
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  2. #2
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    Although the engine came out without issue and initial disassembly went well, it did reveal the first potential problem with engine health. As covered in this thread, the throttle body for #1 and to a lesser degree #2 had a lot of carbon deposits and there was evidence of overfuelling or blowback of unburnt fuel. There is nothing obvious about the cause but the engine had intermittent misfire issues throughout the years that were eventually traced to a failing engine loom that was subsequently replaced 2years ago, so perhaps this is simply the result of that old problem?
    Things turned a bit south when it was time to remove the windage tray that forms part of the Raceline wetsump assembly. It attaches to the mains girdle via five M6 dome head screws held in place by red loctite. The problem is twofold; first,the all alloy girdle and block create a giant heat sink, so it takes a lot of heat on the screw head to get the loctite to the proper temperature to release. Second, the tops of those little dome headcap screws become soft when heat levels are too elevated and subsequently strip very easily. Although I was able to remove two of the five, I had to call in a mobile welder to attach 4mm hex sockets to each remaining screw to aide removal.
    Name:  windage tray bolts sm.jpg
    To avoid this issue in the future, the screws for both windage trays are being replaced with Torx Plus dome head screws from McMaster Carr. The drive profile enables the application of a lot more torque before stripping than the hex drive head of the stock items. Or at least that's the working theory.
    With the windage tray out of the way, the crank, rods, and pistons could finally come out for inspection. Not all was as good as hoped. There is some burnishing on the middle crank main journal that is not visible on the mating bearing surfaces and does not go all the way around journal. Not sure what caused this or if it's a problem. Next, there is some odd staining on the bores of #1 and #2 that looks similar to water spots on glass. Closer examination also shows some damage to #1 in the form of small gash running horizontally about 2" down from the top that easily grabs a fingernail, but is difficult to photograph. The Duratec block can safely be over bored by 0.5mm, so I'm hoping that is more than enough to clean things up. If not, it's time for a new block.
    Name:  bore issue.jpg
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  3. #3
    Join Date
    Jul 2009
    Location
    Arkansas and . . .
    Default
    John, great writeup. I’m curious (my ignorance speaking here); can you sleeve the block (if need be) instead of buying a new block?
    Stalker V8, chassis #85
  4. #4
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    Possibly, but from what I've seen replacement blocks are cheap, so probably not worth the effort. I'll know more once my slot opens up at the machine shop. BTW sorry for not taking your suggestion of titling this thread "Eye Candy" but I thought Croc might take that as an invitation to start posting selfies.
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  5. #5
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    Part of the plan for this project is to correct a few things I never liked with the original engine installation. Back in late 2003 when the order was placed with Raceline for the Duratec conversion parts, I was only the second person to try their kit in a Westfield and the first one with a LHD car. This created unexpected problems like an alternator mount that placed the alternator directly inline with the steering column, a header that fouled the right front wheel on full lock, and engine mounts that were out by a couple of inches on my frame. The local shop that was hired to build my roll bar was also engaged to make a replacement header to Raceline's specs (kind of a long story that may get covered later) and craft new engine mounts based on the Raceline items. Unfortunately when they fabricated the engine mounts, I hadn't yet installed the dipstick tube. Not a big deal, right? Well, when trying to install that part a few weeks later, I discovered their design placed the left hand mount directly over the dipstick port in the Raceline sump. My workaround was a hand formed copper tube attached to a pressure fitting that threads into the port. Although it worked, it didn’t look very professional and always bothered me. The replacement uses a flexible 6AN PTFE hose with a 30 deg fitting that just clears the engine mount and can be easily snaked around the engine mount up through the DTHTBs and looks much better.
    Next on the annoyance punch list is rectifying the lack of a low oil pressure switch and finally installing the mechanical oil temperature sensor that has spent the last 15 years recording under bonnet temps. When designing the interior and dash, I went with Racetech mechanical gauges including a dual gauge for oil pressure and temp. What I didn’t realize until the installation is that the mechanical temperature bulb is big and the only mounting option with my setup was a modified sump plug. For some reason I always put off doing that mod until now. The plug was drilled and tapped to accept the 5/8-16 end of an adapter that mates with the Racetech's 3/8 BSP fitting.
    Name:  oil temp sensor bung sm.jpg
    The pressure switch was another challenge. Heck, just attaching the 3AN fitting at the end of the hose that fed the pressure side of the gauge was a PITA back in the day. The Raceline oil filter plate uses an M12 port. At the time, I was unable to find an M12 to 3AN adapter, so something was cobbled together from 3 fittings that (going from memory) took it from M12 to 8AN, 8AN to 6AN, and finally 6AN to 3AN. Fast forward to today, when Pegasus comes to the rescue. First, they now offer an M12 to 3AN adapter. Second, they have a 3AN female to 3AN male coupler with a 1/4 NPT port on the side -- perfect for taking an oil pressure switch. Here are the old and new adapter setups:
    Name:  oil pressure adapter.jpg
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  6. #6
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    Speaking of the block, as per the Cosworth CSR260 assembly manual, various areas including the mains bearing journal edges, head oil drains, and mains oil feed drillings were de-burred. Here are some before and after photos. As you can see, the state of the head oil drains was pretty nasty. Whether this clean up actually makes a difference, I can't say, but it's easy to do with a small file and a Dremel. If a new block is required, then I get to do it again. BTW for some reason when I copy and paste the text for these posts from another app, the space between random sets of words disappears which doesn't help readability. Apologies if I missed any. I should find an admin and complain...
    Before:
    Name:  block before.jpg
    Name:  oil drain before.jpg
    and after
    Name:  block after.jpg
    Name:  oil drain after.jpg
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  7. #7
    Join Date
    Jul 2009
    Location
    Arkansas and . . .
    Default
    John, this is going to be a very educational thread. As for the de-burring, it’s the equivalent of porting heads; less restriction yields better flow.
  8. #8
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    I was just questioning the degree of improvement. Better oil flow is a good thing, but it's not clear to me if this is fixing an actual problem with the Duratec (i.e. stock oil flow is insufficient at this rpm level) or just an improvement in the strictest sense that doesn't make a practical difference.
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  9. #9
    Join Date
    Jul 2013
    Default
    All the Nth degree things. Sometimes you know, sometimes not. A friend was big into turbo charging engines and started to have his intakes, ports, etc. honed with an abrasive slurry (forget the name of the process). Conventional wisdom was that this is a waste of time, since the turbo will push as hard as needed or tolerable, but in the end it did yield HP. PS: Ferrari boxer engines.
  10. #10
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Excellent thread - we have not had a good engine build thread in a long time. This will put you in the sweet spot of engine power/torque for a road-focused seven that does the occasional track day. Any more and you lose your license the moment you wind out second gear.
    Shane - Not sure you want to sleeve a Duratec block - they are pretty thin walled to start with. Sleeving works well on the older engines with a ton of excess metal and less fine tolerances. Fortunately, they are cheap to buy.
    John - You should link the CSR260 engine build manual to this thread or attach it (preferably). Lots of good information in there that I had forgotten about. Pity all those nice photo icons are so small.
    Mike
    1975 BMW CSL Group 4 (restoration finished - track set up time)
    1985 Holden Commodore SS Group A (suspension restoration)
    1985 Holden Commodore Group A (suspension set up)
    1982 Ferrari 400i (radiator replacement)
    1992 Ford Escort RS Cosworth WRC (dyno time)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
