Page 18 of 21 FirstFirst ... 81617181920 ... LastLast
Results 171 to 180 of 209
Thread: 2.0L Duratec Rebuild
  1. #171
    Join Date
    Feb 2009
    Location
    The Frozen Northeast
    Default
    Why not call the engineers at ARP for a definitive ruling?
  2. #172
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    The ARP values above are from their website for these specific bolts (see link below), so I'm not sure they would provide a different answer. My guess is that from an engineering perspective, 95 ft-lb creates sufficient clamping force, but to Croc's point, SBD has a lot of practical experience in this area with high revving, big power Duratecs. Their approach and slightly higher values are probably what they find best in their builds without failures.
    251-2802.pdf
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  3. #173
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    No progress to report thanks to spending most of the day SUV shopping (yawn). When we returned, I took the Elan out for a much needed, head-clearing blat, but came upon this group just as the corners began 1.5 miles from home. They did not want to move and were in no way intimidated by either the sheer size of the Elan or the angry scream of the revving twincam. I was tempted to try the horn, but it's a Lotus and with my luck it would have released all the Lucas smoke contained in the wiring harness. I'm beginning to wonder if I really screwed up in a past life...
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  4. #174
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    I had a DOH! moment Sunday night. It occurred to me that I never ordered replacement bolts for the pressure plate. After a little digging I was able to secure a set from Massive Performance here in the States which arrived today. Last night I test fit the engine without the bellhousing/transmission to confirm the engine mounts lined up and refresh my memory on wiring and hose routing. Then installed the flywheel and clutch this evening. There are a few more things to do over the next couple of nights, but I might actually be in a place to attempt installation Saturday.
    Name:  engine temp install (3).jpg
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  5. #175
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    It took 90 minutes, a hoist, two floor jacks, a set of jack stands, and shockingly no swearing (honest!), but the engine is in. Still a lot of work to do before first start, but the initial attempt should happen soon.
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  6. #176
    Join Date
    Feb 2009
    Location
    NYC
    Default 2.0L Duratec Rebuild
    Congratulations! A good milestone achievement!
    Mike
    1975 BMW CSL Group 4 (restoration finished - track set up time)
    1985 Holden Commodore SS Group A (suspension restoration)
    1985 Holden Commodore Group A (suspension set up)
    1982 Ferrari 400i (radiator replacement)
    1992 Ford Escort RS Cosworth WRC (dyno time)
  7. #177
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    Ran into a bit of an issue with the accessory belt. The replacement is too small. Digging into it, it appears that the current one, which still has life, has stretched a lot since first installed. Over the course of its life, the steering column was replaced with a newer version that collapses and is slightly larger in diameter. When that switch was made, the belt had already stretched enough to allow that to fit, but a fresh belt creates some interference between the column and the alternator. I have a new, slightly larger, one arriving tomorrow. Other than that, the only things left are bleeding the clutch and getting fresh gas. The rest is done: all fluids, wiring, even the interior is back together. To end the weekend, I installed a special zero timing, zero fuel map in the ECU and cranked it over until I had oil pressure. Woo hoo!
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  8. #178
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    UPS tracking showed a 12:15pm arrival time yesterday for the new accessory belt. It didn't show until nearly 5pm. Although that was early enough to install it and confirm the new size works, it wasn't enough to attempt a cam break in and ring sealing drive. It's raining today. Not sure I want to attempt that process in the wet, particularly given there is no guarantee the car won't leave me at the side of the road. However, I really want to know if it will start, and today does mark the 10 month anniversary of pulling the engine, so I called Kent to confirm that a simple start for a minute followed by a proper break-in drive tomorrow won't create any issues. They told me to go for it. To be safe, the cam lobes received another coating of assembly lube, then 3 fire extinguishers were placed between me and the engine, prayers were made to various deities (gotta cover my bases), and then I gave it a shot.
    At first it wasn't running on all 4, but things started to clear up before the engine was switched off. Quick post mortem revealed the primaries all felt equally warm (good), and the lower radiator hose clamp needed to be a little tighter (easy fix). The smoke seen at the end of the clip should be some coolant burning off that primary which sits directly below the fill location.
    Weather permitting, first drive is tomorrow.
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  9. #179
    Join Date
    Jul 2013
    Default
    It's alive !
  10. #180
    Join Date
    Sep 2006
    Location
    Southeastern Pa.
    Default
    Nice work John, Hopefully you will have a nice smooth break in, and be out hooning around shortly. Good Luck. Tom
    2000 Caterham Superlight #123
    1.8L VHPD Rover K Series
    2009 Caterham SV
    2.3L Cosworth Duratec
Posting Permissions
  • You may not post replies
  • You may not edit your posts
