Results 1 to 6 of 6
Thread: (Help from any track guys) Understeer
  1. #1
    Join Date
    Apr 2018
    Location
    Ft Lauderdale
    Default (Help from any track guys) Understeer
    Maybe it my driving skill (lack of) but I have noticed that I have massive understeer when it comes to long sweeping bends.
    Actually one left hander at West Palm Raceway.
    The car just seems unresponsive and I find myself slowing down more than I think I would need to to take the corner.
    I have tried adjusting the balance by breaking a little into the bend and loading the front but it will not turn in.
    My suspension is rock hard all round would softerning the back end help?
    Life Can Be Cruel
  2. #2
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Can you give us an idea of what speeds you are doing? Entry/midst/exit please.
    Mike
    1975 BMW CSL Group 4 (restoration finished - track set up time)
    1985 Holden Commodore SS Group A (suspension restoration)
    1985 Holden Commodore Group A (suspension set up)
    1982 Ferrari 400i (radiator replacement)
    1992 Ford Escort RS Cosworth WRC (dyno time)
  3. #3
    Join Date
    Feb 2009
    Location
    NYC
    Default
    One other thing - do you have the anti roll bar installed?
    Mike
  4. #4
    Join Date
    Jul 2009
    Location
    Arkansas and . . .
    Default
    Good article addressing understeer:
    https://driver61.com/uni/understeer/
    Stalker V8, chassis #85
  5. #5
    Join Date
    May 2019
    Location
    Memphis
    Default
    Softening the rear will make it worse.
    I had the same issue, turns out the front springs were too stiff relative to the rear.
    If you have an adjustable rear ARB, try moving it to a stiffer setting.
    Sent from my iPhone using Tapatalk
  6. #6
    Join Date
    Jan 2020
    Default
    It could also be technique. If you don't know how to throttle steer you should pick up that skill. A lot of novice understeer issues are caused by them overbraking on entering the corner. This increases the slip angle and may also cause a spin because you unload the rear too much. If you don't know what is going on you will become afraid of corners and aggravate the situation. Learning to manage weight shift on cornering is an essential skill.
    I strongly recommend getting or building a basic racing simulator with a wheel, pedals and shifter and a computer fast enough to handle the simulator software. I use Logitech G29 and iRacing for a novice. I built my own simulator stand with PVC pipe and plywood. With a simulator you get a lot more seat time, you stop being afraid of crashing and can experiment with different driving techniques and cars at minimal expense.
    Anker
    1987 Caterham 1700 Supersprint
    2002 Porsche Boxster
    2004 Porsche Boxster S
    1941 Dodge Luxury Liner
    2009 Mercedes CLK 350 Cabriolet
    2017 Chevrolet Volt
Posting Permissions
  • You may not post replies
  • You may not edit your posts
