Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Thread: Winter plans
  1. #21
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Quote Originally Posted by Anker View Post
    V
    The car is going up on jack stands and if easy the fenders will be removed for easy access. I'll then go through the suspension and brakes with a fine tooth comb.
    Anker - while the car is up, check what the previous owner used to attach the rear wings/fenders to the body. Should be small nylon plastic bolts or fixings. Not metal type.
    The logic is that if you are autocrossing, attending a track day or just meadering along the road and hit something (orange cone, small animal, etc) with the rear wings then the nylon bolts let go without puckering up the sheet ali on the body. Repair is then easier and cheaper. Easy thing to see and fix.
    Mike
    1985 Holden Commodore SS Group A
    1985 Holden Commodore Group A
    1982 Ferrari 400i
  2. #22
    Join Date
    Jan 2020
    Default
    Thank you, Roger,
    I will be doing both, so I'll check that. It does have a deflector bracket in fromt of the right rear wing. Easy to replace. We did the same with radio control model airplanes, for the same reason. Better to break a bolt than rip the plane apart!
    Anker
    1987 Caterham 1700 Supersprint
    2002 Porsche Boxster
    2004 Porsche Boxster S
    1941 Dodge Luxury Liner
    2009 Mercedes CLK 350 Cabriolet
    2017 Chevrolet Volt
  3. #23
    Join Date
    Feb 2009
    Location
    The Frozen Northeast
    Default
    xcar.
    Send him with Larry, just remember to call school daily and say he's still sick.
  4. #24
    Join Date
    Jul 2009
    Location
    Arkansas and . . .
    Default
    Quote Originally Posted by Croc View Post
    I have seen your farming - he deserves to learn how to drive properly!
    Alas.....so true.
    Stalker V8, chassis #85
  5. #25
    Join Date
    Jul 2009
    Location
    Arkansas and . . .
    Default
    Quote Originally Posted by wemtd View Post
    xcar.
    Hmmm. Just might work. His momma is the school admin....but that could be a double edged sword.
  6. #26
    Join Date
    Apr 2013
    Default
    a Tillet seat
    is that fitted in an SV? Which Tillett is ideal for an SV. The one downside I have with the SV is the standard seats donít hold me in position and I am not a nice press fit like I am in an S?
    Jay
  7. #27
    Join Date
    Feb 2009
    Location
    Default
    I haven’t installed mine yet if you want to try it out sometime before it’s in the car?
  8. #28
    Join Date
    Apr 2013
    Default
    yes, I would like to try a test fitting. I can use a wider seat in my car if yours are tight. Which model did you get?
    Jay
  9. #29
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Quote Originally Posted by Black Hole View Post
    is that fitted in an SV? Which Tillett is ideal for an SV. The one downside I have with the SV is the standard seats don’t hold me in position and I am not a nice press fit like I am in an S?
    Hi Jay! Yes - its fitted to my 420R. Its a B7XL-47 with edges cut which makes it 43cm wide. If I did not cut the edges it would be 47cm wide. I used the TB1 brackets for mounting.
    The width is the critical measure - the SV maximum acceptable seat width is 47cm or 18.5 inches. Now you want a little clearance around the sides as you would otherwise carve up the interior side walls with scratches as the seat flexes slightly. Thats why I ended up with the edges cut on the 47cm seat.
    Going from the catalog here:
    https://www.tillett.co.uk/shop/docum...E_2020_WEB.pdf
    There are a lot of Tillett seats that will fit an SV/CSR (do not use for a Caterham S3):
    - B7XL-47 with edges cut 43cm
    - B1 is standard rolled edges is 44.5cm
    - B2 was standard for the Caterham CSR Superlight (same dimensions as the SV) - 44.5cm (using the rolled edges)
    - B4 comes in 40 or 43cm seat width. 40 will fit an S3 Caterham. 43cm will fit an SV. I personally find this seat reclines me too much - 50/60 degree seat angle is better
    - B6 screamer is in 40 and 44cm widths so that works
    - B6XL Screamer 43 (i.e. a 47 with edges cut for clearance) will fit - Bruce at Beachman Racing said to me once he has used it before. I started with this one in my fitting session at Tillett but found I prefered the B7 seat design comfort.
    - B6 40 and 44 regular plus B6XL 43 seem to work
    You can also buy the Tillett seat runners but everyone I know adapts the Caterham seat runners by drilling an extra hole - thats what my 420R ended up as.
    The lead times on Tilletts are pretty horrific so you will have to see what the US dealer has in stock currently. ONe alternative if he does not have anything in stock is to buy off Caterham directly - Tillett make the seats and then Caterham private label them.
    https://caterhamparts.co.uk/seats/30...eat&results=78
    https://caterhamparts.co.uk/seats/62...eat&results=78
    https://caterhamparts.co.uk/seats/67...eat&results=78
    The second alternative for seats is Reverie - another dangerous website with seven goodies.
    https://www.reverie.ltd.uk/seats.php
    I suggest you measure your car to confirm sizing then go comparing.
    Mike
    1982 Ferrari 400i
  10. #30
    Join Date
    May 2010
    Location
    Laurel MD
    Default
    I have 4 things on my winter list, apart from normal maintenence. My first planned outing is early April at Summit Point.
    1. Full roll cage DONE
    2. Swap fuel tank setup, after three changes to the fueling system using just a Aluminum box tank I gave up, I was never able to get rid of the occasional stutter, As I want to give the power a big boost (next winters project) this was not exceptable. So after tanking to Dan Lipperini I went for a twin tank setup, 2 4 gallon tanks. DONE
    3. Remove the pedal box and add a brake light switch, I do not trust the hydraulic pressure switch I am currently using. They are know to be unreliable and it's in a real tricky place should it need replacing, plus you have to bleed the rear brake so it's not a quick swap. STARTED
    4. Modify inlet manifold to stop it being water cooled, part of an ongoing project to lower inlet air temps. All parts on hand.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
