Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Chassis Stands
  1. #1
    Join Date
    Nov 2006
    Location
    Higganum, CT
    Default Chassis Stands
    As my new Caterham kit is soon to be arriving, I was wondering if anyone had any experience with chassis stands being used in place of the typical axle stands. I have a couple different sets of axle stands but I'm intrigued by these chassis stands because of the available 28" height and how that would help an old guy like me work on the car. https://www.pegasusautoracing.com/pr...p?Product=3175
    Attached Images Attached Images
    Bruce
  2. #2
    Join Date
    Sep 2006
    Location
    Southeastern Pa.
    Default
    Hi Bruce, it's been almost 20 yrs since I assembled mine using standard jack stands. My question to you is how much help do you have? When I assembled mine, I did everything on the stands, including the motor and gearbox. So when it came time to put it on the ground, I was worried about the balance and the stands being pulled/tipped when lowering one end. I had four friends hold on to the back end as I lowered the front, just to make sure it didn't slip.
    If you have it up 28 inches, I'm just wondering how you get it on the ground as you add weight.
    Tom
    2000 Caterham Superlight #123
    1.8L VHPD Rover K Series
    2009 Caterham SV
    2.3L Cosworth Duratec
  3. #3
    Join Date
    Jun 2007
    Default
    I used saw horses when I built mine https://www.homedepot.com/p/Stanley-...0626/203799620
    Used them until I had the suspension installed and then set it on the ground with the help of 3 friends and finished the build using jack stands.
    2006 Caterham 7 SVT(sold)
  4. #4
    Join Date
    Feb 2009
    Location
    The Frozen Northeast
    Default
    Being a good Yankee i use cinder blocks & a pair of 4x4's. it lets me adjust the height and prevents lower back strain from bending over.
  5. #5
    Join Date
    Jul 2009
    Location
    Arkansas and . . .
    Default
    Quote Originally Posted by yellowss7 View Post
    . . . If you have it up 28 inches, I'm just wondering how you get it on the ground as you add weight.
    .....well
    Stalker V8, chassis #85
  6. #6
    Join Date
    Oct 2006
    Location
    Cincinnati
    Default
    See the currently active Rotus-rebuild photos for his chassis stand solution.
    Kitcat:AKA, Sir Spinsalot
    '09 Birkin S3, Duratec-sold
    '03 Caterham Zetec track car
    '19 Honda Type R, sold
    '19 Miata Clubsport
  7. #7
    Join Date
    Nov 2006
    Location
    Higganum, CT
    Default
    Thanks for all the help guys...and for the laughs! I was planning on doing all the work I could do with it up on the stands and then lower it to the ground (or the lower axle stands) and then install the engine/transmission. I think I'm going to try them out because I can always use them on my vintage race chassis too when I start working on that. Or I might just get that lift I've always wanted if I could just get my garage done.....
    Bruce
  8. #8
    Join Date
    Feb 2009
    Location
    Default
    I can't remember what works best for a Caterham. But i long ago found the birkin engine/gearbox goes more smoothly lowering down onto a dolly. (I've lost track of how often it's happened)
  9. #9
    Join Date
    May 2010
    Location
    Laurel MD
    Default
    I used a pair of folding leg saw horses set on the lowest setting. rated at 1200 pounds. Worked perfectly on the lowest setting it was just at the right height for working on.
    Graham
    https://www.amazon.com/WORKESS-WK-SH...647302&sr=8-16
  10. #10
    Join Date
    Dec 2010
    Default
    2000, 2002 Caterham 7 America
    Ferrari 308 (1976)
    Lola T596 S2
    BMW 1 series
    BMW Z3 M Roadster
    BMW 2002 DTM wanta-be
    2015 Silverado to pull it all with
Posting Permissions
  • You may not post replies
  • You may not edit your posts
