Results 1 to 4 of 4
Thread: Front turn signal bulbs
  1. #1
    Join Date
    Dec 2013
    Location
    Owings Mills, MD
    Default Front turn signal bulbs
    I've got a front turn signal out so need to change the bulb. Can't see for sure how to get the beehive off to access the bulb.
    Appreciate the advice to change the bulb.
    Thanks,
    Jim
  2. #2
    Join Date
    Sep 2006
    Location
    Southeastern Pa.
    Default
    Jim, I seem to recall when I assembled my car they they just press fit into the rubber gasket, the trim ring just presses in as well. A bit of a pain to get them in but I'm pretty sure there are no bolts or screws involved.
    Tom
    Mangia bene, Ridi spesso, Ama molto, Guidare veloce
    2000 Caterham Superlight #123
    1.8L VHPD Rover K Series
    2009 Caterham SV
    2.3L Cosworth Duratec
  3. #3
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    I carefully use a pick to remove/replace. Just run it between the underside of the rubber gasket and the top of the lens (or metal trim ring if you have that style) and pry down as you pull up on the lens. There is generally a lot more swearing and need for alcoholic beverages when attempting to reinstall it.
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  4. #4
    Join Date
    Dec 2013
    Location
    Owings Mills, MD
    Default
    Thanks guys. Looked like it might pull off put didn't want to pull too hard and break something.
    I'll have a beer before I try to put it back together!
    Jim
Posting Permissions
  • You may not post replies
  • You may not edit your posts
