Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
Thread: ECU Recommendations
  1. #11
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    Quote Originally Posted by Croc View Post
    Yada yada yada, yada yada yada, yada yada yada, yada yada yada...
    So to summarize, you were wrong. Glad I could help clarify. Shane, it's your turn!
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
  2. #12
    Join Date
    Feb 2010
    Default
    Thanks Croc. Emerald makes a harness specifically for a Duratec in a Caterham:
    http://www.emeraldm3d.com/duratec-ca...erald-ecu.html
    I'm making my own chassis harness and will probably use this Emerald engine harness if I go with their ECU (which I probably will).
  3. #13
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Letís be honest on this forum. Men are never wrong. The results of their failures are usually pretty spectacular though! :-p
    Mike
    1985 Holden Commodore Group A
    1982 Ferrari 400i
  4. #14
    Join Date
    Jul 2009
    Location
    Arkansas and . . .
    Default
    Youíre doing great....and Iím enjoying the moment.
    Stalker V8, chassis #85
  5. #15
    Join Date
    Jul 2013
    Default
    Not just Thanksgiving. It's like an early Christmas.
  6. #16
    Join Date
    Jul 2007
    Location
    Parker, CO
    Default
    My R400 has an AEM EMS-4 in it. I just bought the car so I'm still learning about it, but it seems like a decent unit. I can try to answer any questions you might have.
    Thomas Jordan
    2008 R400 Superlight
  7. #17
    Join Date
    Aug 2007
    Location
    USA
    Default
    In Southern California, Bisi at Bisimoto Engineering has hands-on experience tuning Duratec Caterhams with MBE ECUs as well as some other brands of ECUs the names of which I cannot recall, although Bisi had help from Magnus at the time, and Magnus has since moved away from So Cal. Steve at SBD or Simon at Meteor Motorsport are good reference sources of MBE info. At one time, SBD could supply harnesses for a variety of MBE applications, and probably still can.
    Sean
  8. #18
    Join Date
    Feb 2010
    Default
    For those doing power upgrades to their existing Caterham Sevens with MBE controllers, the easiest path is an aftermarket MBE 9A4, which is pin-compatible with the "locked" factory MBE's.
    For those wishing to upgrade *exactly* along the Caterham specification curve (e.g. R300->R400->R500), we might have a very cost-effective solution for you. PM/email for details.
    Cheers,
    -Bruce
    Beachman Racing
    Authorized Caterham Cars dealer
  9. #19
    Join Date
    Dec 2019
    Location
    Belgium, 15min from Zolder, 1H from SPA
    Default
    When I upgraded to a 1.8K series I decided to use an Emerald. The base map allowed me to run the engine without op much hassle and the self learning loop worked like a treat. Ten years later I dropped by with Emerald themselves to have the car properly mapped after a rebuild. The only place they had to change more then a few % was low down around 2500rpm ... you donít spend enough time there with different throttle positions for the car to learn.
    Sent from my iPhone using Tapatalk
  10. #20
    Join Date
    May 2014
    Default
    You guys are so far beyond me re: ECUs!
    I know where it is. In the effort to fix my issue I grounded it externally. That was a pain in the ass and didn't help. How do you guys access the ECU? Remove the passenger seat and lie on your back with a headlight?
    My ZETEC is running rich at idle. My guru says it might be any ECU problem. He's very diligent but I don't know where I should be focussing my efforts now. Who idles for long anyway?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
