Results 1 to 6 of 6
Thread: Wanted: Powertrain
  1. #1
    Join Date
    Feb 2010
    Default Wanted: Powertrain
    I'm about to embark on a 7 project and am looking to put together a powertrain to drop in it. I am currently planning on a stock 2.0 Duratec with throttle bodies and aftermarket ECU, coupled with a T9 5-speed and likely a 3.92 diff with Quaife ATB.
    Before I start sourcing parts, I thought I'd see if anyone has any of these bits. For example, 2.0 Duratec long block.
    Cheers!
  2. #2
    Join Date
    Jul 2009
    Default
    I have a new unused 3.9 diff. No lsd fitted.
  3. #3
    Join Date
    Jan 2018
    Location
    Northern Virginia
    Default
    I have a T-9
  4. #4
    Join Date
    Dec 2014
    Location
    Los Angeles
    Default
    I have some Duratec accessories if you end up needing them. New starter, cam covers, stock cams, ITG air filter for the ITBs...
    Good luck
  5. #5
    Join Date
    Feb 2010
    Default
    Quote Originally Posted by CarlB View Post
    I have a T-9
    Message sent.
  6. #6
    Join Date
    Feb 2010
    Default
    Quote Originally Posted by papak View Post
    Good luck
    Thanks, I’ll let you know!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
