Page 4 of 4 FirstFirst ... 234
Results 31 to 34 of 34
Thread: Zetec Power output
  1. #31
    Join Date
    Aug 2016
    Default
    Quote Originally Posted by 1turbofocus View Post
    he just felt for 125.00 an Hr a higher class of wiring should of been done
    This exactly.
    The wiring to the relays are pretty basic and what I'd expect for a DIYer or a quick fix. It'll work, but it doesn't look like what one would pay someone $125/hr to make.
    For replacement, if that Bosch relay fails (unlikely), you have to create a wiring diagram, pull the wiring, unscrew the relay, and replace. With relay holders, you pop the relay out and toss a new one in. For $125/hr, I'd expect that kind of convenience and higher-end wiring.
    The rest of the loom is fine. Raychem would make it more reliable, cleaner, and have a higher resistance to temp -- but at a higher cost.
    Mind you, I just redid my chassis and engine wiring looms, so it's all fresh to me.
    - 1300lbs, 170bhp. British.
    - 2350lbs, 610whp. British.
    - 2700lbs, 180bhp. German with a British accent.
    - 2700lbs, 200bhp. German.
    - 4700lbs, 577bhp. German.
  2. #32
    Join Date
    Jul 2011
    Location
    Ontario
    Default
    In a car as light as a 7, 30 hp is going to make a big difference. I had a Westfield with a 2l built Vauxhall at about 185 hp. Now I have a Superformance S1 with a mostly stock 2l Zetec. Westfield was like a rocket compared to the S1.
    What can I add to my fuel stabilizer to make it last longer?
  3. #33
    Join Date
    Apr 2018
    Location
    Ft Lauderdale
    Default
    Couple of short Videos showing the Air Fuel (but as I did not note the RPM rather pointless)
    And the fuel Pressure
    Any thoughts would be welcomed
    https://youtu.be/w-o5iL4orUE
    https://youtu.be/D8UlF-fwqSg
    Life Can Be Cruel
  4. #34
    Join Date
    Nov 2010
    Location
    NC
    Default
    Hard to tell on the A/F , what is the WOT air fuel , what is the steady throttle A/F at different RPM ?
    Fuel psi at 50 psi ? Thats kinda high if it is , 38-42 psi is Avg normal AF for that
    Tom
Posting Permissions
  • You may not post replies
  • You may not edit your posts
