Page 1 of 8 123 ... LastLast
Results 1 to 10 of 74
Thread: Getting atrocious mileage?
  1. #1
    Join Date
    May 2018
    Location
    Albany, NY
    Default Getting atrocious mileage?
    Since buying the 7 last year I'm still slowly figuring and sorting out misc problems as I've put maybe 500 miles on the car, likely under that.
    The recent is that I feel like I'm filling up far too often. I don't have a working odometer as the speedometer has been swapped for a SPA unit since original build and the speed output hasn't worked right for at least 10 years from what I've gathered. I don't even know if it's tranny pickup or hall sensor on rear axle (didn't see anything on axles)
    Now while fixing that is on the list, I've decided to test the MPG the old fashioned way. Filled up in one area, drove 8 miles highway and filled up again. Used right around 1.1 gallons.
    Today I drove about 50 miles and am at half tank already.
    Lets say empirically, with variables I average 10mpg. Thats quite low isn't it?
    2001 Zetec, Jenvey ITB's, injectors have been swapped to high impedance. Pectel ECU.
    I haven't done a compression test but thats probably going to happen soon.
    Car feels quite peppy but I can't tell if I'm down on power as I have nothing to compare it to.
    Oil doesn't smell like gas.
    No obvious leaks anywhere, I fixed a previous return like leak.
    Any ideas of what else to check for? I should be getting about 20mpg or more, no?
    2001 Caterham Superlight R
  2. #2
    Join Date
    Apr 2013
    Default
    Certainly pull your plugs to see if they indicate that you've been running rich. Does the Pectel ECU tuning software give you the opportunity to check your AFRs through the rev range?
  3. #3
    Join Date
    May 2018
    Location
    Albany, NY
    Default
    Quote Originally Posted by jcerier View Post
    Checked the plugs and I'll upload pictures but in meantime I created a new problem.
    Some of the crud around spark plug has fallen onto the cylinder and now I'm trying to master mind a way to get it out.
    I know nothing about data logging the Pectel unfortunately. I'll have to look into it.
  4. #4
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Quote Originally Posted by Vovchandr View Post
    Vacuum cleaner - adapt something as a nozzle to fit into the spark plug hole.
    Mike
    1985 Holden Commodore SS Group A
    1985 Holden Commodore Group A
    1982 Ferrari 400i
  5. #5
    Join Date
    May 2010
    Location
    Laurel MD
    Default
    I think your new problem has answered your first question. If you have that much crud on the plugs your probably running very rich.
    Graham
  6. #6
    Join Date
    Jul 2009
    Location
    Arkansas and . . .
    Default
    Portable air tank. Blow it out with compressed air.
    Stalker V8, chassis #85
  7. #7
    Join Date
    Aug 2008
    Location
    Iowa
    Default
    Quote Originally Posted by xcarguy View Post
    That would probably blow more chunks into the crevice above the top ring than back out the spark plug hole. I like the idea of taping clear plastic tubing to a vacuum cleaner hose better.
  8. #8
    Join Date
    May 2018
    Location
    Albany, NY
    Default
    Here are some pictures.
    #1 tunnel - only really dirty one
    #1 plug
  9. #9
    Join Date
    May 2018
    Location
    Albany, NY
    Default
    Cylinder and rest of plugs
  10. #10
    Join Date
    Feb 2009
    Location
    NYC
    Default
    What is that stuff on the plugs? Mud?
    Mike
    1982 Ferrari 400i
Posting Permissions
  • You may not post replies
  • You may not edit your posts
