Results 1 to 7 of 7
Thread: Dellorto parts in USA?
  1. #1
    Join Date
    Apr 2013
    Default Dellorto parts in USA?
    I need new studs to mount my Dellorto DHLA 45 carbs to their manifolds. Can anyone recommend a source within the US? Looking online the only possibility I've found is CB Performance. They show lots of parts but I don't see the studs. Need to get them ASAP...
  2. #2
    Join Date
    Nov 2006
    Location
    Higganum, CT
    Default
    Did you try calling them? They might not have it listed. You can also check with Pierce Manifolds. They're a Weber dealer but I would think the hardware would be very similar. Here: https://www.piercemanifolds.com/default.asp
    Bruce
  3. #3
    Join Date
    Apr 2013
    Default
    Pierce Manifolds had the studs, and Thackery washers. Thanks so much.
  4. #4
    Join Date
    Nov 2006
    Location
    Higganum, CT
    Default
    Glad they were able to help.
    Bruce
  5. #5
    Join Date
    Nov 2015
    Location
    NJ
    Default
    Mcmaster-Carr should have everything you need. You just need to know the size and pitch of the threads.
    https://www.mcmaster.com/threaded-rods
    One of these is very handy as well.
    https://www.threadtoolsupply.com/wal...d-checker.html
  6. #6
    Join Date
    Apr 2013
    Default
    FYI I tried McMaster, and they didn't have what I need. Seems these items are specific to European carb mounting.
    Quote Originally Posted by John B View Post
  7. #7
    Join Date
    Apr 2013
    Default
    A bit more info for the record: Don't know why I didn't think of them to begin with, but Dave Bean Engineering has everything for this. They even have custom stainless studs that are machined specifically for this application with slightly larger diameter shafts to better locate and stabilize the carbs. The Dave Bean catalog, and Ken at Dave Bean, were both very helpful.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
