Results 1 to 7 of 7
Thread: Dash: Buttons vs Switches
  1. #1
    Join Date
    Apr 2019
    Default Dash: Buttons vs Switches
    I have noticed a few Caterhams with buttons on the dash instead of the more common switches; for example: http://vintageracecarsales.com/portf...ham-seven-480/
    Is there any anecdotal information about which is more reliable? I don't see this change listed as option on the Caterham Configurator, so perhaps it is no longer offered.
    Thanks,
    Jim
  2. #2
    Join Date
    Feb 2009
    Location
    NYC
    Default
    The current standard Caterham fitment is the dash buttons in the linked ad. The older cars used plastic toggle switches.
    The exception to this is the 620R (and maybe by special option) which have a metal toggle with the protector hoops alongside.
    Mike
    1985 Holden Commodore Group A (restoration - engine rebuild)
    1982 Ferrari 400i (will repaint to original color in 2020)
  3. #3
    Join Date
    May 2018
    Location
    Albany, NY
    Default
    Quote Originally Posted by kayentaskier View Post
    Thanks,
    Jim
    There are at least 4 or 5 different dash configurations that I know of that Caterham has offered between buttons style and gauges or even the CSR style swooping layout.
    Switches have been (and I believe still are, even according to the Caterham configurator) the standard layout.
    Button/switch reliability is a bit of a strange question. Typically it's a simple electrical contact adjustment in either style and lasts a lifetime, especially with how little use our cars typically see further compounded by how much less frequently buttons get used. If any external factor like sitting outside would cause one to fail/corrode it would likely cause the other style to fail as well.
    I will say one thing, typical switches have plastic that tends to fade over time and sun exposure, buttons or metal toggles might be better in that regard.
    2001 Caterham Superlight R
  4. #4
    Join Date
    Apr 2019
    Default
    Thanks for the responses. The Caterham UK website shows many pictures on new (current) cars with the plastic switches; which both my 2000 Superlight and 2007 Superlight R came with. As Vovchandr mentions, the plastic switches fade over time, which is why I was curious about the buttons. I realize the configuration of the dash changes with the options on the car (eg., wipers, heater, etc,).
  5. #5
    Join Date
    May 2018
    Location
    Albany, NY
    Default
    Funny you say that. To my understanding the actual layout is the same regardless of whats on your car due to bolt on nature of our cars. Dash will always have the same amount of holes and they will all be filled with switches regardless whether you bought a heater or ordered a windshield at all.
    Mine are quite faded but honestly after purchase I haven't thought twice about it (that is until I got into this discussion now...)
    Share what your SL and SLR look like!
    Here are the variations that I know
ID:	15316   Click image for larger version.
ID:	15317   Click image for larger version.
ID:	15318   Click image for larger version.
ID:	15319   Click image for larger version.
ID:	15320   Click image for larger version.
  6. #6
    Join Date
    Apr 2019
    Default
    I have sold both cars and don’t think I have pics of either dash. Now that you mention it, I think the 2000 Superlight came with wiper and heater buttons even though neither options we’re included.
  7. #7
    Join Date
    Apr 2018
    Location
    Ft Lauderdale
    Default
    Yep mine had both
    Life Can Be Cruel
Posting Permissions
  • You may not post replies
  • You may not edit your posts
