Results 1 to 6 of 6
Thread: Racing harness - anti submarine belt mounting?
  1. #1
    Join Date
    Nov 2015
    Location
    NJ
    Default Racing harness - anti submarine belt mounting?
    4-point harnesses no longer pass tech at NJMP where the 2019 7's HPDE event will be held, and my belts are out dated anyways, so I've ordered two sets of 6-Point Sparco racing Harnesses.
    My question how have you guys mounted the anti-submarine belts (the ones that go between your legs)? I don't think mounting them to the thin aluminum floor would be a good idea, nor pass tech.
    The cross bar that is in front of the seat?
    The same bolts the lap belts are secured to?
    Any other ideas?
  2. #2
    Join Date
    Nov 2010
    Location
    New Jersey
    Default
    There are a number of threads on the Lotus Seven Club forum on this. https://www.lotus7.club/forum
    First check behind your seats as you may have brackets attached to the rear crossbar. It wasn’t for belts, it was for a different seat type, but can be adapted with a spacer and bolted through the floor. The other most common option is on the same bolt as the lap straps. The forward crossbar is too far forward for the belts to function and not a great idea to drill that anyway.
    That Sparco harness looks like it will need modification to use bolt in fittings.
    1985 Caterham Super Seven
    1952 MG TD
    1991 Lotus Elan
    2017 MX5 RF
    2018 Audi A5 Sportback
    2014 BMW X1
  3. #3
    Join Date
    Jul 2009
    Location
    Arkansas and . . .
    Default
    John,
    You have the clip-in style. Something like this may be the ticket: https://www.ogracing.com/brey-krause...lt-c6-corvette
    Stalker V8, chassis #85
  4. #4
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Hopefully these photos assist
    I was able to tap an existing mount in the CSR chassis tube for the 5th and 6th point belts - right at the base of the rear firewall in the cockpit.
    I run the leather Caterham seats. I run the anti submarine belts up between the seat backrest and removable seat base. I then sit on the belt.
    Mike
    1985 Holden Commodore SS Group A
    1985 Holden Commodore Group A
    1982 Ferrari 400i
  5. #5
    Join Date
    Nov 2015
    Location
    NJ
    Default
    That's very helpful guys, thanks. I did get the bolt ins, but grabbed the wrong pic.
  6. #6
    Join Date
    Jan 2018
    Location
    Northern Virginia
    Default
    I think you will find this helpful. It is from the foundation that writes the rules on racing safety equipment for the US
    http://racequip.com/images/SFI_Guide_to_Seat_Belt_Mounting_06-05-12.pdf
Posting Permissions
  • You may not post replies
  • You may not edit your posts
