Page 3 of 20 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 200
Thread: Sevens Event - NJMP Drivers Club June 28-30, 2019 - Final Event Details
  1. #21
    Join Date
    Nov 2015
    Location
    NJ
    Default
    Registered, room, & trailer. I'm really looking forward to it!
    I'm still trying to resolve some last minute tweaks for the track though.
    6 point harnesses - Done.
    2 degrees front camber - Done.
    I'm trying to fit a set of Brooklands screens on my SV but Caterham doesn't supply the scuttles to mount the Brooklands on SV's, they only supply them for the narrower S3's so I purchased a narrower one and will try to have a section welded in to make it fit. Then mirrors...
    I picked up another set of VTO wheels to mount identically sized 205/50 15 Hoosier A7's as the Direzza's that were on for the street, but although the Hoosiers are the same "size", they apparently aren't the same "dimension". The inside of the tires hit the front fender stays. I need about another 3/8" of clearance. I may try to modify the stays, or go fenderless on the front. We'll see
    Nothing is easy, but we'll be there!
  2. #22
    Join Date
    May 2010
    Location
    Laurel MD
    Default
    John for 3/8" s wheel spacers is an option. Not a perfect solution but it should work.
    Graham
  3. #23
    Join Date
    Nov 2015
    Location
    NJ
    Default
    Thanks Graham, I think I'll try putting a spacer in the bottom mount but I'll also have to make the hole the ball joint bolts though in the fender bracket into an open slot as there's not 3/8" room left there and that's closer to where the tire hits the bracket. It looks like that might be ok as that's how the CSR brackets are anyways although they may have another mounting point as well, I'm not sure. Worst case I can just just weld it back up.
  4. #24
    Join Date
    Jul 2010
    Location
    Potomac, MD
    Default
    Fred here. Thanks for asking Graham. She's all better now. Can't make the party this year due to a conflict. Have fun.
  5. #25
    Join Date
    May 2010
    Location
    Laurel MD
    Default
    Sorry to hear you not coming this year, love the car, just what a 7 should be, simple.
    Graham
  6. #26
    Join Date
    May 2010
    Location
    Laurel MD
    Default
    Registered, hotel booked, tow vehicle reserved, car inspected. Cannot wait
    Graham
  7. #27
    Join Date
    May 2018
    Location
    Albany, NY
    Default
    I'll be the oddball
    Not registered, hotel not booked, tow vehicle pending, car still in progress.
    New seatbelts came in this week with the extra 2 points, will take time to install.
    Arm restraints have arrived as well.
    Fuel sender gasket is still in the transport webbing somewhere.
    Alignment is pending weather clearing up (should I go neg 2 degree like John B or just standard OEM specs?)
    etc etc.
    2001 Caterham Superlight R
  8. #28
    Join Date
    Feb 2009
    Location
    NYC
    Default
    No not really. I am used to those having a panic realization on the first day that they have out of date belts, out of date helmet, worn bearings, etc and failed tech. Phone calls at 2pm the day before asking me to find a hotel room - oh and it has to be cheap. Trust me, after so many years doing this I have seen it all with ill prepared participants.
    You have a whole month to procrastinate yet. Plenty of opportunity to improve!!!!
    Sent from my iPhone using Tapatalk
    Mike
  9. #29
    Join Date
    Oct 2006
    Location
    Cincinnati
    Default
    More like 21 days Croc, assuming it takes a travel day to get there. I am going to need all 21. My car, having just gotten a rebuilt engine, new clutch, flywheel etc., has sprung a transmission leak and likely rear diff leak. Hopefully parts will be available and are not on "back order". It could have been worse, the original diagnosis was a rear main seal problem.
    Kitcat:AKA, Sir Spinsalot
    '97 Caterham Super Sprint, 1700 Crossflow-sold
    '09 Birkin S3, Duratec-sold
    '03 Caterham Zetec track car
    '19 Honda Type R, sold
    '19 Miata Clubsport
  10. #30
    Join Date
    Sep 2005
    Location
    St. Louis, MO
    Default
    I’m set for accommodations (staying at the track again), but that’s about it.
    Plan is to take care of mechanicals this week. Try the new cooling arrangement again, new brake fluid, check brake pads (have an extra set front and back), figure out why Mike’s Brooklands don’t fit, install new 6 point harness. Easy, right?
    The following week is for polishing.
    Steve
Posting Permissions
  • You may not post replies
  • You may not edit your posts
