Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Duratec camshaft change
  1. #11
    Join Date
    Feb 2009
    Location
    The Frozen Northeast
    Default
    I’ve got some diagrams if you pm your email address should you proceed with the change
  2. #12
    Join Date
    Jul 2016
    Default
    You can change them in the car (SV, anyway) - gonna be a job though.
    Main hurdle will be getting the torque-to-yield crank bolt out, and sourcing new diamond friction washers for crank/cams.
    Everything in front of the motor between the motor and next chassis tubes needs to come out obviously. In my case this meant the oil tank needed to come out.
    All in all it's not a bad job, just make sure you source all the critical parts such as the diamond washers, crank bolt, cam plate (tool) and timing pin bolt (tool) ahead of time.
  3. #13
    Join Date
    Dec 2014
    Location
    Los Angeles
    Default
    Not sure if my pm got through. kpkehoe@ca.rr.com
  4. #14
    Join Date
    Feb 2009
    Location
    Default
    Once or twice...
    Hang in there
Posting Permissions
  • You may not post replies
  • You may not edit your posts
