Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 65
Thread: Getting My 7 Tomorrow!
  1. #41
    Join Date
    Jan 2018
    Location
    Wellsboro, PA
    Default
    The headers are chromed if that's what you mean.
    I took the wings and fenders to a customer of mine to have bedliner material applied to the underside of them to prevent gravel and some damage. I'll get them back on Thursday. I live in a very rural area with a lot of macadam and dirt roads. Better to be safe than sorry.
    Unfortunately the car won't start... Seems to be a wiring issue. It won't even crank unless i jump the solenoid on the starter. Derek with Caterham sent me a writing diagram but just the engine compartment, hopefully I'll get the chassis one tomorrow.
    Hopefully I'll get it sorted soon! Dying to hear it!
  2. #42
    Join Date
    Apr 2018
    Location
    Ft Lauderdale
    Default
    Pics Please
    Life Can Be Cruel
  3. #43
    Join Date
    Jan 2018
    Location
    Wellsboro, PA
    Default
    I hope you meant the headers...our did you mean the fenders and wings?
  4. #44
    Join Date
    Jan 2018
    Location
    Wellsboro, PA
    Default
    I picked up the wings and fenders yesterday. He sprayed four layers of bed liner material on the under sides. They came out great and I think they will very well protected from stones!
  5. #45
    Join Date
    Jan 2018
    Location
    Wellsboro, PA
    Default
    On the starting problem.... Does anyone checking in here have a newish 7 they could check on some wiring for me?
    When I checked the relays, 1st... I found that Caterham put the turn signal flasher where the starter solenoid belongs :facepalm at least the blinkers work now!
    Secondly, when I checked the voltages on the back side of the starter relay, I discovered that 3 of the 4 wires have 12v being applied to the wires. The odd man out is a double black pair of wires that lead to the starter solenoid. When I apply 12v to that pair of wires the starter engages and spins the motor over.
    I find this troubling in that I know that one of those wires should be a ground and not have voltage on it.
    The wires are brown, purple/blue(it goes to the ignition relay) and the other is a small black/red wire. Like I said they all have power to them. Not being an electrical engineer even I know that there has to be a ground in order for the relay to engage. Is this the same B/R wire that runs thru the starter button? Does the starter button have 12v applied to it or does it supply the ground when pushed?
    Any Thoughts?
    Kenny
  6. #46
    Join Date
    Nov 2006
    Location
    Higganum, CT
    Default
    Kenny - I found an assy guide for a Ford Sigma that has a wiring diagram at the back. Not sure if it's the same as yours but it might be of help in case Caterham hasn't gotten you the chassis diagram yet. Check it out here: https://www.sevener.fr/articles_reda...uide_Sigma.pdf From this wiring diagram, it looks like the four wires at the starter relay are White/Red, Brown, Brown/Red, and Black/Red.
    There's also this one but I didn't see a wiring diagram: https://www.sevener.fr/articles_reda...1.0_Screen.pdf
    Good luck, I'm going to be doing something similar 6 months from now!
    Bruce
  7. #47
    Join Date
    Jan 2018
    Location
    Wellsboro, PA
    Default
    Thanks Bruce I'll give them a look!
  8. #48
    Join Date
    Jan 2018
    Location
    Wellsboro, PA
    Default
    Not much help I'm afraid... but thanks. This is very similar to the one Derek sent me. At least this one has a starter button on it, the one I have doesn't... lol. The relay block is totally different than mine. I think these diagrams are actually drawings for the manufacture of the wiring harness. Those light printed numbers in between junctions, terminals and connectors etc. are distances in MM's. Close to a diagram but not quite. I've been staring at the one I have for two days and I still can't find where N52 terminates, I see it at the starter, relay but I'll be darned if I can find where it goes.
    Thanks again, Bruce!
    I'll keep you posted,
    Kenny
  9. #49
    Join Date
    Jan 2018
    Location
    Wellsboro, PA
    Default
    Up and running! Apparently or my guess would be, the diode in the relay fizzed when Caterham put it where the flasher was supposed to be. Just by dumb luck and a case of well maybe the damn relay is bad, I put a different relay in, that I had laying around and she started! Life is good!
    I managed to salvage some of the weekend and wired up and mounted the repeaters on the cycle wings. Pain in the butt getting the wire thru the wing support. Hint... Feed a very thin wire (I used phone wire) up from the bottom, tie off the repeater wire then pull the works back down thru. Works great!
    Next up, gluing the cycle wings on. I purchased some professional grade 2 part metal bonding epoxy from a body shop on my Snapon route. I don't want to take any chances of the wings flying off! They use it instead of welding body panels together. They say it's stronger than welding.
    They said to sand the wing uprights down to bare metal so the epoxy bonds to the metal better. I filed the paint completely off where the fender and support will meet. Also left the metal a bit rough for better bonding.
  10. #50
    Join Date
    Nov 2006
    Location
    Higganum, CT
    Default
    Congrats Kenny, glad it was a defective relay and didn't involve a miswired or defective harness. You've made great progress, keep it up!
    Bruce
Posting Permissions
  • You may not post replies
  • You may not edit your posts
